99 Honda Accord temp gauge stuck!
Old Jul 5, 2013 | 03:35 PM
RIPTEC's Avatar
Default 99 Honda Accord temp gauge stuck!
My temp gauge is stuck and never moves! Even when I shut the car off or turn the car on it is in the same position at all times. How can I fix this gauge??? I just blew my radiator and found out that one of my fan motors was shot. I replaced both the fan and radiator, but now I really need to figure this temp gauge out asap. I need to know how hot my engine is running! Thanks for any help guys!
Old Jul 6, 2013 | 04:25 AM
Lost Again's Avatar
Default Re: 99 Honda Accord temp gauge stuck!
Is the gauge stuck all the way up - down - or somewhere in the middle?
Have you checked the connection at the sending unit?
Old Jul 6, 2013 | 12:20 PM
RIPTEC's Avatar
It is stuck right about normal operating temperature. I would check the connection, but I'm not sure where it is exactly. I think it is on the coolant hose coming out of the back of the engine by the v-tec solenoid sticking straight up. Does that sound right?
Old Jul 7, 2013 | 03:30 AM
Lost Again's Avatar
I'll assume this is a four cyl by your description of the engine - guessing
The sending unit is on the end of the head - it is the single pin sending unit. This pic is a bit misleading - that housing is where the "upper" rad hose connects to the engine.
Old Jul 8, 2013 | 10:28 AM
RIPTEC's Avatar
It is the 4 cyl engine... would this be on the front of the engine or the back of the engine?
Old Jul 8, 2013 | 07:20 PM
RIPTEC's Avatar
Ok... I found it. I tested the connector wire that snaps on the sending unit and it was reading 0.89 volts. Is this good or bad? I don't know what it should read.
Old Jul 9, 2013 | 08:39 AM
Lost Again's Avatar
Pull the connector. Ground it to the block/head. Turn the key to on and watch the temp gauge - does it start to go towards Hot? ALSO be sure to turn the car off or un-ground the wire before the gauge gets all the way to Hot....this can damage the gauge.
Old Jul 9, 2013 | 03:59 PM
RIPTEC's Avatar
I tested the connector and got no response from the temp gauge, but I'm not sure that I'm doing this correctly either. I just ran a wire from the inside of the connector and had it touching the head of the motor. Could you explain how exactly i'm supposed to ground the connector to the head/block? Otherwise, if i did it correctly and got no response, what does that mean? Thanks for helping me on this.
Old Jul 9, 2013 | 07:24 PM
jdowen2's Avatar
Is the number 9 fuse (7.5A) in driver's underdash fuse/relay box good? Are you grounding YEL/GRN wire?
Old Jul 9, 2013 | 11:05 PM
RIPTEC's Avatar
Ok... The number nine fuse is good. Yes the connector wire is yel/grn, but am I grounding it correctly? By just running a wire from inside in the connector and just touching the head of the motor with the other side of the wire.
Old Jul 10, 2013 | 07:09 PM
jdowen2's Avatar
That is the correct way to test, if you have a good connection to ground. If the ground connection is good you may have a bad gauge, bad pcm, or open wire.
Old Jul 11, 2013 | 08:24 AM
Lost Again's Avatar
The temp on these didn't go to/thru the PCM until 2000. So I'm with either a bad gauge or broken wire....more like the gauge as it is "stuck" around normal op temp.
Old Aug 12, 2013 | 04:26 PM
RIPTEC's Avatar
Hey guys, I'm back... I got a sending unit really cheap so I just threw it in to see if that was the problem and nothing changed! DAMN, I was hoping that was just going to do it...
Old Aug 12, 2013 | 04:28 PM
RIPTEC's Avatar
Also, I did notice that the ECT sensor is leaking, or at least it looks like it is that's for sure... Just relaying all the info that I have on my end to try and figure this problem out.
00CIVICHATCHMAN
Aug 10, 2011 06:45 PM
acc0rdf22
Apr 11, 2010 03:05 PM
TshingY
Jan 25, 2010 12:59 PM
CivicRenModelX
Jan 10, 2008 06:56 PM
ButterMule
Nov 27, 2004 10:19 AM
