New ID 1300's
Old Jul 3, 2013 | 08:51 PM
Desir Performance's Avatar
Default New ID 1300's
Ok so it's official Injector Dynamic recently released the 1300's to their injector line, has anybody tried them and or have feedback?
Old Jul 4, 2013 | 03:47 AM
The sweed's Avatar
Default Re: New ID 1300's
I have just order a set and will get on the dyno as soon as I get them.. They have stainless internals for e85 and can handle pressures.. I hope they will work good at idle and low loads. I will run them with e85. Very exited.. I have been waiting on these for a while for my own engine and hope they´ll be enough.. I was hoping for something more like 1600cc.. Mabe in a while..
Old Jul 4, 2013 | 06:09 AM
SPOOLINmatt's Avatar
run em at 100 psi and im sure they'll be atleast 1600cc
Old Jul 4, 2013 | 06:52 AM
300M's Avatar
"run em at 100 psi and im sure they'll be atleast 1600cc"
LOL, on what fuel pump are you trying to achieve this feat with?
Old Jul 4, 2013 | 07:32 AM
A Bosch? This is old news doing 100psi base pressure.
Old Jul 4, 2013 | 07:38 AM
DaveF's Avatar
we ran 80-90 psi base with a mechanical fuel pump, and would see rail pressures of around 155 or so during a run.
Old Jul 4, 2013 | 08:25 AM
300M's Avatar
a mechanical fuel pump I believe. However, electric? now I've got to see this one. 100psi base fuel pressure and still have maximum linear fuel delivery thru out the power band. Given the fact that a typical drag setup will rev out @ 11,500 +/- 500 rpm.
Old Jul 4, 2013 | 08:52 AM
sanman000719's Avatar
are you new or just hard of hearing man
100psi is easy just crank the regulator i did it with rc1000's and had over 1300cc with them making 650 on e85 and a aeromotive a1000
Old Jul 4, 2013 | 09:32 AM
300M's Avatar
http://i1209.photobucket.com/albums/...0flowsheet.jpg
http://i27.photobucket.com/albums/c1...eromotive2.jpg
http://www.jegs.com/DynoChart/0/027/...101diagram.jpg
http://i160.photobucket.com/albums/t...pFlowRates.jpg
The above links are some flow charts.
"are you new or just hard of hearing man
100psi is easy just crank the regulator i did it with rc1000's and had over 1300cc with them making 650 on e85 and a aeromotive a1000"
pretty simple to crank up the regulator to your specific fuel delivery needs, so easily done, any MORON can do it.
Old Jul 4, 2013 | 10:32 AM
tepid1's Avatar
As you increase pressure you lose flow. What are you trying to prove?
Old Jul 4, 2013 | 10:55 AM
so if increasing pressure decreases flow then you should be able to make more power at lower pressure then at high??????
Old Jul 4, 2013 | 11:41 AM
tepid1's Avatar
Depends, decreases pump flow, not injector flow.
Old Jul 4, 2013 | 12:21 PM
exactly that was my point you can increase injector flow to unlock a little more power, and i agree you sacrifice pump flow while doing so,
some people can afford the bigger injectors, and the bigger pumps so this is what we do at that time.
Old Jul 4, 2013 | 12:31 PM
We were doing 775 on a Bosch fed by a walbro. 100psi base. 6262 83mm
Id1000
Old Jul 4, 2013 | 01:03 PM
AllShowNoGo727's Avatar
What are the advantages of running these 1300's over the id2000's? Is it just the price, or am I missing something?
Old Jul 4, 2013 | 01:28 PM
Ryan97's Avatar
ID1300 or FIC 2150/Grams 2200 for the same price.. If you are an ID fanatic then why not spend the extra couple bills for nearly twice the injector that has been proven over and over..
Old Jul 4, 2013 | 08:52 PM
STREETMASTERS!'s Avatar
Great thread, definitely going to look into these!
Old Jul 5, 2013 | 07:23 AM
tepid1's Avatar
The 1300's are compatible with MBTE
Old Jul 5, 2013 | 12:46 PM
twkdCD595's Avatar
Yup. MBTE fuel compatible, ID's precise matching/ data, etc...
Also let's not overlook these are built exclusively for only ID by Bosch Motorsports.
TurboSpoolinInside
Jul 24, 2011 06:06 PM
Tchleung
Feb 27, 2005 07:52 PM
BoOsTiN Dc2
Apr 8, 2004 03:10 PM
djnikko
Dec 7, 2003 08:09 AM
ATS*Mark
Nov 4, 2003 05:11 AM
