Transmission & Drivetrain Gearboxes, Differentials, Clutches
Tranny not fully disengaging in neutral?
Old Jul 1, 2013 | 11:20 AM
FiReSTaRT's Avatar
Default Tranny not fully disengaging in neutral?
99 Civic EX - After doing a brake job, with the front end lifted up, when I run the engine, the driver side hub is turning forwards slowly. (*) The force on it is so light I can easily stop it with my hand and the wheel doesn't turn when the tires and rim are mounted. When I press in the clutch the hub stops turning, so it looks like there is a bit of engagement. I'd really appreciate your thoughts on:
1) What could be causing this?
2) How to fix it?
3) How much am I harming the car by leaving it in this condition?
Thanks in advance, guys!
(*) I haven't noticed this when the entire car was up on stands (and level) but I wasn't looking for it so I may have missed it, just throwing it out there in case it may be relevant.
Old Jul 2, 2013 | 06:57 AM
cruizinmax's Avatar
Default Re: Tranny not fully disengaging in neutral?
This is normal. Nothing to fix.
Old Jul 2, 2013 | 07:43 AM
kyden's Avatar
normal.
Old Jul 2, 2013 | 08:32 AM
FiReSTaRT's Avatar
Thanks for setting my mind at ease guys. If you don't mind letting me know what does that.. Curious minds'd like to know
Old Jul 2, 2013 | 02:04 PM
94EG8's Avatar
Seagull Management
The fluid in the trans is what's turning it. Completely normal.
Old Jul 2, 2013 | 04:58 PM
FiReSTaRT's Avatar
Thanks. On a good note, it's nice and fresh :D
clean EX
19
Apr 23, 2013 10:44 AM
bluevic99
Oct 9, 2011 04:55 AM
webguy330i
Jan 23, 2005 07:27 PM
southphillyman
May 29, 2004 10:24 AM
