gas gauge drops to empty when I start delsol
Old Jun 30, 2013 | 04:15 PM
sexyblack973's Avatar
Default gas gauge drops to empty when I start delsol
Hello, need help. I have a 93 delsol manual trans. . One morning while driving noticed my gas gauge on empty so pulled to gas station filled up, gauge went to full. When started the car went about two blocks gauge read empty again, pulled over, turn the key to on position needle went to full, started driving and again same thing. Did that until got home. Also noticed when I put on the hazzards only the front works and the gas gauge goes really fast to empty. Now today started looking for any thing obvious turned the car on same issue. the radio wire hit the metal and sparked and now it doesn't turn on now. What could I have blow looked at fuses none are blown and can anyone help with gas gauge problem? Please HELP!!!!
Old Jun 30, 2013 | 05:39 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: gas gauge drops to empty when I start delsol
You have a blown fuse. It's at the fuse box under the dash. Carefully remove the radio and make sure the ILLUMINATION orange wire is securely covered. That is what made the "spark".
Old Jun 30, 2013 | 05:45 PM
Hi thanks, but I don'dt have a radio. I was trying to find out why my gas gauge was acting weird and I saw and herd the spark, I put tape over the exposed wire and try to start it and no click or crank my lights dimmed when I turned the key.
Old Jun 30, 2013 | 05:50 PM
NVturbo's Avatar
O.G. triple O.G.
If your lights dim out when you try to crank the engine, your BATTERY needs replacing.
Old Jun 30, 2013 | 05:57 PM
Thanks, do you now about why my fuel gauge goes to empty when I put my hazzards and the two in the back don't blink? They do signal but the two back hazzards don't. Thanks appreciate it
Old Jun 30, 2013 | 06:02 PM
NVturbo's Avatar
O.G. triple O.G.
the fuel gauge issue and hazard lights may have to do with either a shared power circuit....or they are two separate issues on their own. Is the car "wire tucked" by the way?
Old Jun 30, 2013 | 06:06 PM
Yes .
Old Jun 30, 2013 | 06:07 PM
NVturbo's Avatar
O.G. triple O.G.
......you just answered your own question. IT's time to check the wiring. Honestly, the only way to do a proper wire tuck job is solder and cover with heatshrink tubing. Anything else will result in electrical issues down the road.
Old Jun 30, 2013 | 06:13 PM
Thanks.
Old Jul 1, 2013 | 08:24 AM
Hi, found the crazy problem with the gas gauge. It was a fuse .I looked at it wasn't blown. So today bought a fuse tester checked them out . Really weird though, the one I replaced worked it wasn't blown and now the car won't start. I turned the key to on and heard luke 20 clicks all in a row then the clicking stopped. Took the relay which was main fi relay out waited a couple of mins.put it back in and when turn to on position I hear only one click. Also, weird I tested other fuses with the test light and the left and right high and low beams didn't light the tester but , my lights all work fine. Can I get some feed back ? Could it be the main F.I. realy?
Old Jul 1, 2013 | 09:11 AM
Former User's Avatar
Not weird -- You would have lit up the test light had you turned the light switch on.
Old Jul 1, 2013 | 09:35 AM
Ryan Lwin's Avatar
If it just click, your battery is dead. Not enough power to crank. Get the battery tested at auto shop. I think you have a short circuit somewhere to drain the battery and make other electrical components act funny. You might wanna take out the cluster and check behind it. Using wiring tap, tape every wires that you think is exposed. Also pictures please.
Old Jul 1, 2013 | 10:11 AM
Hello again , I tested alll fuses with the ignition on pisition. I clutch started the car and left it running for about an hour, turn the hey and no go. I'm taking it to a mechanic. I think it's the main relay due to it clicked like a machine gun and then stopped.Now it only clicks once.
Old Jul 1, 2013 | 11:25 AM
Ryan Lwin's Avatar
Sounds like dead battery or loose battery connection.
Old Jul 1, 2013 | 01:07 PM
Hello again, would you believe I took the car to a shop HOURS AGO. Icalled to find out the statis on my delsol. He said I looked and looked and could't find the problem. Is that a bunch of BULL SH!! T Aint it. Now I bet he's gonna what alot of money. Well, thats what he thinks ..I'm gonna clutch start it and take it where I originally wanted. It's two towns over and we had down pours all day thats why I didn't take it to my original place. I mean this mechanic owns a cpuple of handa civics. Cam't believe it.
Old Jul 2, 2013 | 02:52 AM
NVturbo's Avatar
O.G. triple O.G.
Some mechanics know how to replace damaged or non-working parts but have no clue when it comes to electrical troubleshooting. My advice is to check it out yourself with an electrical multimeter. It will give you a better understanding plus save you money in the long run.
Old Jul 2, 2013 | 02:58 PM
Buckshot870's Avatar
A couple of people have said it might be the battery, did you even take their comment into consideration?
Old Jul 3, 2013 | 03:19 AM
NVturbo's Avatar
O.G. triple O.G.
x1937434932473
Like I said before.......
IT
IS
THE
BATTERY
Old Jul 5, 2013 | 06:13 AM
Hi, changed battery and starter. Mechanic said it was the starter anyways car is running. Now, another problem I have a crime stopper sp500 remote start/alarm. My pink/white wire is for ign2/acc where does that wire hooks up to on the ignition harness ? Is it the black and yellow? Thanks for all the help.
Old Jul 5, 2013 | 07:02 AM
Ryan Lwin's Avatar
It was the battery. Starter was clicking because there was not enough. Well. You wasted money for starter already. Soooo. Have fun.
Old Jul 5, 2013 | 09:26 AM
The click was the relay, I felt it clicking when I put my hand and I already had the starter purchased it last year due to 3 mechanics said my starter was going . Thanks. I'm having an issue with remote start I think while I was messin around under the dash I know the pink wire from the remote goes to the ignition the manual says pink and white wire is for ignituon 2 and accessory but I don't know which color on the ignition harness.
Old Jul 5, 2013 | 12:03 PM
Ryan Lwin's Avatar
Get the manual for the remote system. You need the wiring diagram. Or else you'll fry the system.
Old Aug 15, 2013 | 10:00 AM
Okay now, had crazy problem with gas gauge etc. Found a big hole in the exhuast. Changed exhuast and somehow all my problems mysteriosly went away Oh! and change the starter dwcided to throw it in since I had it new in the box in my teunk since last year. Anyways, problems all fixed so weird though. Also THANKS to all for your feed backs.
Old Aug 15, 2013 | 10:51 AM
Nbboy7's Avatar
WOW
civic_saints1
Sep 25, 2007 07:55 AM
Munkz
Honda Civic (2001 - 2005)
Dec 19, 2006 07:24 PM
variable_x
Jul 29, 2006 10:05 PM
