Compression test 210-215-180-180
Old Jun 30, 2013 | 07:43 AM
doublezerohatch's Avatar
Default Compression test 210-215-180-180
The numbers were generally the same with 2 different heads on the motor . . . . The 2 cylinders #3 and #4 with high compression the spark plugs are covered in oil and deposits . . . the other 2 cylinders with around 180 lbs have perfect looking spark plugs . . .
Is it possibly some stuck rings, maybe seafoam could help me or is it just time to pull the motor? the high compression baffles me. . . is the oil really sealing it up better.
I have another motor on my shop floor it has 180 lbs straight across the board.
is around 180 the average stock number . . .
Old Jul 1, 2013 | 05:36 AM
kyden's Avatar
Default Re: Compression test 210-215-180-180
have you done a leakdown? compression rings don't stick, the oil control ones do, which have nothing to do with compression readings.
Old Jul 1, 2013 | 08:03 AM
sleepyaccord96's Avatar
have block inspected by machine shop.
rebuild engine.
call it a day
JDMtype Eg6
Jul 14, 2007 02:31 AM
D-Rob
35
Apr 12, 2006 10:57 AM
InLimbo87
Nov 4, 2004 05:05 PM
hondaeg8
10
Jul 25, 2004 11:13 AM
LsTurbo91
May 12, 2002 07:52 PM
