Compression on a Newly Built Motor
Old May 12, 2002 | 07:42 PM
LsTurbo91's Avatar
Default Compression on a Newly Built Motor
When a newly built/rebuilt motor is assembled and the rings have not seated burning a lil oil here and there. Is the compression low compared to when it has seated, does the compression yield higher numbers or not by much?
For example when compression is checked at 10miles its 160 and at 1500m its 220.
Old May 12, 2002 | 07:52 PM
sgT's Avatar
sgT
Default Re: Compression on a Newly Built Motor (LsTurbo91)
All of my motors the rings seat immediately and the numbers will start out
in the normal range and go up as time goes on.
The motor shouldnt burn oil and have low compression.
sirguy01
Jul 6, 2006 09:03 PM
siis2fast
Jun 16, 2003 11:09 AM
sjracer
Jan 21, 2003 03:28 AM
