New VSS Help!
Old Jun 28, 2013 | 07:53 PM
crazyhouse2011's Avatar
Default New VSS Help!
I have seen videos of VSS replacement on my D16Z6 5 speed. Besides removing the intake is there anything i need to look out for? Calibration? On a somewhat related note, I need to find my transmission code. It's either a A000 or B000. Where could I find that stamped?
Old Jun 28, 2013 | 07:58 PM
grumblemarc's Avatar
The Grumpiest
Default Re: New VSS Help!
Surely it should be on the transmission? Regardless, it's a D-series.
Old Jun 28, 2013 | 08:05 PM
Well the last owner swapped out the auto for a manual. He did such a damn good job that it had me fooled. Except the carpet was not attached under the door sills (ECU), the clutch pedal didn't match, the PRND321 was on the gauges (but didn't light up), but I looked up the VIN months ago and figured out it was a factory auto. ANYWAY... it's time for a clutch replacement. But before I have them drop the transmission I want to BE SURE IT IS THE 5 SPEED IN THE 95 CIVIC EX FACTORY MANUAL. Not some other transmission. Or does that even matter? I haven't worked on trannies before. And I knew where the VSS is, just wanted some pointers as what NOT to do. Thanks.
Old Jun 28, 2013 | 08:26 PM
The Grumpiest
Just put in a VSS from a D-series.
Old Jun 28, 2013 | 08:35 PM
Ryan Lwin's Avatar
I don't understand. You wanna install VSS right? If you have small hands, you don't need to remove intake. But yes. To have clear space to work with, just remove the intake. Then take the old VSS out and put the new VSS in. That's it. What's all this about clutch changing? Off topic?
Old Jun 29, 2013 | 07:16 PM
Thanks. But I'm just trying to figure out WHERE on the transmission the code is stamped BEFORE I get under the car.
Old Jun 29, 2013 | 07:35 PM
B_Swapped93's Avatar
has to be from a manual D afaik the integra ones work to. it's plug and play.
Old Jun 29, 2013 | 08:28 PM
Ryan Lwin's Avatar
You don't need to go under the car for vss
Old Jun 30, 2013 | 06:16 PM
I knew THAT. I was talking about where to find the transmission code stamp on the tranny.The VSS is directly under the throttle body on top of the tranny.
Old Jun 30, 2013 | 07:25 PM
Former User's Avatar
Old Jul 8, 2013 | 01:09 PM
Thanks bud. I can see that sticker. But There is supposed to be a A000 or B000 code stamp somewhere on my tranny. Where the ***** do i find this ****? Thanks.
thenext
Aug 31, 2011 05:22 PM
black0hatch
Jan 29, 2010 04:59 AM
Mxzack999
Oct 7, 2007 09:32 AM
dubbedcorde
Dec 6, 2004 04:16 AM
abeaujuin
Mar 19, 2003 07:54 PM
