vtec not engaging
Old Jun 27, 2013 | 04:08 PM
efkilla's Avatar
Default vtec not engaging
i have a ef with a obd1 vtec conversion no check engine light just feels like vtec is not hitting checked everything please help
Old Jun 27, 2013 | 04:45 PM
crvtectim's Avatar
Default Re: vtec not engaging
Have you removed the solenoid to check the gasket's screen filter for clogs?
Old Jun 27, 2013 | 06:02 PM
JayDeeMmm's Avatar
I hope you get help here. I have the same problem and havent had any luck here. I have been told that I need make sure the vss wire from the cluster matches up with proper pin on the ecu, some jumpers are off. I would think I would have a cel if that was the case. I have hondata on the way so I should be able to get it to engage.
swizz977
10
May 25, 2011 08:15 PM
crx-b18c
Sep 26, 2008 09:15 AM
JDMFREAK2002
May 10, 2005 03:00 PM
SLOAZZ95
Aug 13, 2004 08:31 AM
