What piece is this?
Old Jun 27, 2013 | 01:04 PM
1sick4g63's Avatar
Default What piece is this?
Trying my first manifold and found this pic. I need the square piece.
Do they make Sch10 in square or should I just use some standard 1/8" stainless?
And anyone know what the dimensions I need for a t3 flange are? I don't yet have the flange to measure.
Old Jun 27, 2013 | 02:15 PM
Hidenplanvew's Avatar
Default Re: What piece is this?
Its a turbine inlet flange http://www.turbo-flanges.com/index.php Has them towards the bottom of the page in turbine flanges
Old Jun 27, 2013 | 02:30 PM
1sick4g63's Avatar
I have a flange on order, but I need to know what size the rectangle is or if it has a specific name that will space out the manifold from the flange.
Old Jun 27, 2013 | 05:15 PM
I think they call it a log manifold turbine flange... Other then that I am unsure, check that web site and see if they give more information
Old Jun 27, 2013 | 06:01 PM
1sick4g63's Avatar
Found this,
http://www.jgstools.com/turbo/thp.html
But rather buy from a reputable place.
Old Jun 27, 2013 | 06:32 PM
HellaFab's Avatar
go buy some rectangle stock an mitre into it with a hole saw the same as the od of the pipe.
cost you about the same to buy the mandrel and the hole saw (if you have a drill press to use)
Old Jun 27, 2013 | 07:10 PM
1sick4g63's Avatar
Don't have a good one
Old Jun 27, 2013 | 10:57 PM
Just buy from the site I posted before, its 35 bucks muchhhh cheaper then making it your self.
Old Jun 28, 2013 | 04:12 AM
HellaFab's Avatar
if it costs you that much to make it yourself your doing something wrong.
Old Jun 28, 2013 | 10:10 PM
There are alot of things that could affect that price.. If he dosent have the correct things to make it then its pointless... Hole saw, drill bit and tap will run more then just buying two flanges. Plus its a waste if he doent plan to do more then one.
Old Jun 29, 2013 | 04:14 AM
1sick4g63's Avatar
It's true. I have a small little bench top drill press, not a really good hole saw either. So it makes sense to just buy the one. Besides, no place I can just run to to get metal. Most of those places are open 8-4:30 m-f.
1lowek2007
Welding / Fabrication
Dec 8, 2013 04:24 PM
rvs51
Jun 19, 2013 08:04 PM
sdr KEL
Nov 6, 2012 09:04 AM
area522010
Aug 19, 2010 06:22 AM
