95 ej1 b16a swap
Okay im looking at a obd1 jdm b16a with a gsr lsd tranny the guy wants 1000 for it the motor is clean as hell. Im wondering if this is a good buy and what else i would need to swap it into my 95 civc coupe it just the motor and trans nothingelse
Cant ascertain if its good buy or not, but you will need motor mounts, cv axles, half shaft, ecu, and wiring harnes if your car is not wired for vtec. There are plenty of threads explaining what a B-Swap requires.
I don't know what you heard but you can't just "tune" an ECU. First it has to be OBD1. Then it needs to be socketted. Finally it has to have VTEC capabilities if you're running a VTEC head. You need to do more research about this swap before you even think about making the purchase.
r1cerocket7o2
May 20, 2014 12:22 PM
91d15bvtec
Aug 30, 2004 06:02 PM
