quick question on idle issues
Old Jun 22, 2013 | 07:49 AM
Yobee's Avatar
Default quick question on idle issues
hey HT i have a 91 honda civic hatch with a b18b1 swap everything is great except when i start it in the mornings drive somewhere such as burger king for breakfast i park go in and come out to start the car it starts right up but when i put it in reverse and start to back up the rpms bounce at around 1-2000 rpms and then to actually get the car to move i have to rev it up past 2000
(happens in every gear)
im thinking its either the tps sensor or iacv. what does it sound like to you guys?
it doesnt always do it but when it does its hella annoying.
i also have been hearing you can take off and clean the iacv and its suppose to be just as good as new? im not sure i just want the issue resolved.
thanks.
Old Jun 22, 2013 | 02:22 PM
Yobee's Avatar
Default Re: quick question on idle issues
no help
Old Jun 23, 2013 | 09:16 PM
SpokaneSpeed's Avatar
Have you attempted to clean your IACV, or test your TPS? Have you inspected/tested your ignition components? Is the car converted to OBD1? What ECU are you using to run the B18B1?
Please include as much information as possible about your vehicle, setup, recent maintenance, etc..
Old Jun 23, 2013 | 09:57 PM
silkypillows's Avatar
drive-thru? lol jp.
low coolant/air in cooling system
IACV sticking
FITV - out of adjustment (should be closed when engine is at operating temp.)
ECT malfunction
with any other form of internal/external vacuum leak being a potential cause, although doubtful if the problem does not exist when the engine is at temp.
Check engine light on?
Old Jun 24, 2013 | 09:24 AM
2000CTRSi's Avatar
Tps
Old Jun 24, 2013 | 07:41 PM
Yobee's Avatar
Originally Posted by silkypillows
drive-thru? lol jp.
IACV sticking
ECT malfunction
no check engine light, coolant level is good. like i said it happens periodically and recently hasnt done it at all. it may have been because the car sat for almost 3 months before it turned into my daily. if it happens again i'll attempt to clean the iacv.
cjwang2
Jul 8, 2016 01:10 PM
hYbRid_Eg6
Mar 22, 2011 12:05 PM
smokinloc
Mar 8, 2010 01:39 PM
ThatOneOG
Dec 7, 2008 12:30 PM
87manche
Feb 5, 2007 11:53 AM
