Gauge Cluster Problems
Old Jun 21, 2013 | 01:36 PM
gtkid2002's Avatar
Icon2 Gauge Cluster Problems
TL;DR: Tach works, not sure on temp gauge, no speedo/odo, no gas gauge. All lights on dash work when key turned to run. No CEL.
Long version:
Hey everyone. Just picked up a '95 Accord DX that had a bad igniter. PO's replaced most of the ignition system (coil, cap, rotor, wires, I got it new plugs). Started, but noticed the only gauge I had working was the Tach. No CEL lights or error codes, but the lights do come on when I first turn the key to run, as they should. Tach works, temp sensor twitches it seems (haven't ran it long enough to see if it will go on, but it moves about 1/8" when key turns to run, so not sure on this one). No fuel gauge, no odometer, no speedometer. No CEL. Tapped the blue/white wire underneath the steering column and hooked it up to my multimeter on the HZ selection and drove it a little, noticed that it was sending pulses (so that should be a good VSS if I did pick the right wire).
Bad ground somewhere? Should I pull the cluster and give it a go-over with a soldering iron, or try and find the ground points?
xsicrx120
Sep 23, 2009 02:00 PM
Kinfer
Jan 13, 2008 09:47 PM
hedtrip
15
May 22, 2006 08:02 PM
Sack Master
Oct 22, 2004 04:49 PM
troubledsol03
Oct 1, 2004 09:20 AM
