Bumper Bolt
Old Jun 21, 2013 | 06:06 AM
rah140's Avatar
Default Bumper Bolt
u
Old Jun 21, 2013 | 06:11 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Bumper Bolt
Trick question? You use a Hex or a Torx to remove it depending on what it actually is. Without posting a pic I don't know how you expect an accurate answer.
Old Jun 21, 2013 | 06:30 AM
rah140's Avatar
Beacuse a technician, who works on the car everyday, will know what size tool is needed to remove the bolt. For instance, if the car was a 2012 Honda, the technician will know from experience that you need a 10MM socket to remove the bumper bolt.
Please don't respond if you don't know the answer
Old Jun 21, 2013 | 07:14 AM
The Grumpiest
Can the attitude. You don't even know what you have on there. And to top it off you said it's not stock because they have been "changed to something else". So how is a tech supposed to know what's on there now? You cannot even tell us if it's a Torx or a Hex bolt.
A 10mm bolt probably transfers to an M6 hex. People can only guess.
Advice? Stock your toolbox better.
Old Jun 21, 2013 | 01:56 PM
rah140's Avatar
I said that they changed from 2012 to 2013, which a tech would know. What a bunch of jerks on this forum. I will be cancelling my subscription
Old Jun 21, 2013 | 04:24 PM
The Grumpiest
No. You said it was changed and you didn't know to what. I'm guessing you don't have a decent tool set that you can just figure this out on your own? That you don't even know on sight if the bolt on it now is hex or Torx doesn't help, regardless if it changed from '12 to '13 (but you know that it did?). Perhaps you need to invest in a field service manual? Or better yet, just call up a Honda dealer parts department? Or go to someplace like hondaautomotivepartsonline and look up the part?
Old Jun 21, 2013 | 04:28 PM
burnoutboy's Avatar
The Credible Hulk
Originally Posted by grumblemarc
Can the attitude.
Ironic **** is super ironic.
Old Jun 21, 2013 | 04:32 PM
The Grumpiest
Maybe. But I can tell a torx from a hex. You need a Honda tech to tell you that?
Old Jun 21, 2013 | 04:37 PM
burnoutboy's Avatar
The Credible Hulk
I wasn't disagreeing with you at all in this instance, just sayin' LOL.
Old Jun 21, 2013 | 04:40 PM
The Grumpiest
I don't disagree either.
I just don't see how you catch an attitude because you can't tell what it is you're looking at.
HomeDepotMade
Jan 21, 2006 12:39 PM
Buktheng
Nov 16, 2004 07:24 PM
is3oo
Oct 4, 2003 01:48 PM
pdiggitydogg
Jun 25, 2003 01:35 PM
rasta420
Jul 5, 2002 01:26 PM
