Completely Painting New Rotors To Prevent Rust. Will it last?
Old Jun 19, 2013 | 04:48 PM
Vagitarian's Avatar
Default Completely Painting New Rotors To Prevent Rust. Will it last?
Hey guys, just looking for some advice, for a few years that ive been repairing cars, I have been painting the rotors before I put them on, but I only ever paint the center hub hump part, leaving the face and outside edge bare, which usually leads to rust, and my autozone rotors this time rusted in less than a year.
What I am planning on doing this time is paint the ENTIRE rotor, with atleast 3 coats, including the faces that the brake pads will squeeze against, will probably take me 2 days, paint one side per day so I can flip the rotor without marring the fresh paint
Has anyone done this method? Will it prevent the rotors from rusting for much longer than if left exposed to the elements? I like the look of rust free rotors.
Im assuming that if I do this, I can just install the new rotors momentarily with the OLD pads still installed, go for a quick rip and a few brake pedal pushes and the old pads will strip the painted surface area.
Then I can put the new pads on and properly break them in on the fresh surface? Has anyone done this method? Worth all the extra trouble? Or just buy a rotor with a zinc coating and run them out of the box
Old Jun 19, 2013 | 04:58 PM
doood's Avatar
been there done that
Default Re: Completely Painting New Rotors To Prevent Rust. Will it last?
to clarify, what is the point of painting the faces if the first time you hit the brakes all that paint will be stripped off anyway?
Old Jun 19, 2013 | 05:30 PM
Vagitarian's Avatar
Well the pad doesnt touch the full face of the rotor, theres quite a bit that goes untouched if I didnt paint the faces that I think would be exposed to elements
I dont see a more efficient way to paint the entire rotor
Old Jun 19, 2013 | 06:10 PM
DeadlockRiff's Avatar
Throw one coat on the edges and on the bell (and ghost any dark spots) with cast spray paint, throw it on the car 25 minutes later and stop worrying.
Old Jun 20, 2013 | 05:22 AM
kyden's Avatar
buy centric premium rotors. done.
Old Jun 20, 2013 | 02:56 PM
KevinEF7's Avatar
Even centric premiums rust quite quickly, especially on a DD in rain and salt
I think the paint method is great, , I personally have only ever painted the center hub bump, but I think your onto something painting the hole rotor completely and shaving off the contact area with the used pads before you change them
Only downside being the time of take the tires and calipers off more than once.
Has anyone tried this?
Old Jun 20, 2013 | 03:16 PM
kulo's Avatar
Just paint hubs
ZAKU
Mar 1, 2008 06:24 PM
CG_EJ8
14
Nov 9, 2004 11:19 AM
Marcos
Jul 21, 2004 11:45 PM
Marcos
Jul 20, 2004 06:51 PM
kb58
16
Jun 10, 2004 09:36 AM
