water pump
Old Oct 24, 2002 | 06:30 AM
turrismaldon's Avatar
Default water pump
i have a honda ccord '90 lx (146,000 mi)and the water pump leaks and was advised to might as well have the timing belt changed (coz i wonder if the first owner did changed it)to while replacing the water pump would i need to have cam shaft belts and balance belts too changed? can i do it in my backyard or would i need a lift or hoist?
thanks
Old Oct 24, 2002 | 06:34 AM
urbanlegend21's Avatar
New User
Default Re: water pump (turrismaldon)
cam-shaft belts?
balance belts?
that is your timing belt
I suggest changing it at that many miles
Old Oct 24, 2002 | 06:37 AM
Default Re: water pump (urbanlegend21)
i went to napa and gave me choices like timing belt, balkance belts and cam shaft belt is it all synonymous? ty
Old Oct 24, 2002 | 07:30 AM
New User
yeah, your timing belt runs from your cam to your crank pulley(balancer)
there is one other belt that runs your altenator, power steering, and A/C
Old Oct 24, 2002 | 08:03 AM
Gus's Avatar
Gus
There's two belts involved. One is the timing belt. It goes around the camshaft pulley and the crankshaft pulley. It also runs your water pump. Your motor also has a balance shaft in it. There is a seperate belt for that. It goes fromt the crankshaft pulley to the balance shaft. Both of these belts and the water pump are behind the timing belt cover. You'll have to take off the power steering pump and alternator and stuff to get to it. Get a haynes manual and it will tell you everything you need to know.
The belts on the outside that you can see; there is one for the power steering pump. The other runs the alternator and the A/C compressor.
Old Oct 26, 2002 | 06:56 AM
97accordex's Avatar
You can probably find someone to do it for around $500-700. Its kind of a big job and you need the right tools. You will need an impact wrench for removing pulley (might as well put lighter ones in there).
Yes do water pump, all belts and pulleys if you have the $.
Do as much as you can while you are in there. Will save time & $ in the long run.
Old Oct 26, 2002 | 10:10 PM
SPIRIT7623's Avatar
Here ya go............ http://www.cybertrails.com/~bestinth...otipsmain.html
That should help.
Old Oct 28, 2002 | 07:40 AM
Default Re: water pump (SPIRIT7623)
so does everybody says that if i go to napa and order the timing belt adn water pump they would also be giving me the balance shaft belt and the cam shaft belt with it?
and as i order the water pump will it have the necessary seals i need?
thanks
Old Oct 28, 2002 | 08:01 AM
fcardoso's Avatar
I work at an autoparts store in Canada and you should only ask for a Cam belt (also known as timing belt) and Balance shaft belt, and no the waterpump only comes with gaskets and o-rings!!
You will need to order cam and crank seals and balance shaft seals!!
Old Oct 29, 2002 | 07:33 AM
Default Re: water pump (fcardoso)
thanks Fcardoso!
wouldi need to change cam and crank shaft and balance shaft seals too... actually my problem is just the water pump.but i was advised by the mechanic to change the timing belt as well.... by doing so will he be ale to change the balance shaft belt too and does gaskets?
thnaks
metroya_performance
Sep 17, 2007 05:21 PM
zracer240
Aug 1, 2005 10:07 AM
JaiDieM
Sep 11, 2003 06:55 PM
d mafia
Aug 19, 2003 05:20 PM
