B16A help please?
Old Jun 18, 2013 | 08:42 AM
JDM3JDude's Avatar
Default B16A help please?
Thanks for the Help with the 2 TB nipples, now I am confused on where the Nipple from the Lower T stat housing connects? The other on my Intake Manifold an last but not least the black canister near the fire wall connects to? any help please...really want to get my car rolling
Old Jun 18, 2013 | 08:45 AM
Fliptard's Avatar
Default Re: B16A help please?
left one runs to the IACV on the back of the manifold. Right one runs to a nipple either straight across near the thermostat housing, or across around the top rad hose adapter at the head
Old Jun 18, 2013 | 08:55 AM
JDM3JDude's Avatar
Thanks, now that just leaves me wit a couple more. I was thinking the other one may run to the long coolant chamber tube on the back side of the block being that is open as well?
Old Jun 18, 2013 | 08:59 AM
Fliptard's Avatar
the nipple on the black coolant tube, running across the back of the block goes to the other port on the IACV
Old Jun 18, 2013 | 02:24 PM
JDM3JDude's Avatar
got a few more????s if anyone has a chance to help out!
Old Jun 18, 2013 | 03:05 PM
Fliptard's Avatar
what else?
Old Jun 18, 2013 | 03:52 PM
JDM3JDude's Avatar
I got the one's from my Throttle body hooked up. now if you check out pic two I have a nipple on the thermostat housing. 3rd one over which I think is a water bypass hose but dk where to run it an than in the same pic I have a open nipple on my Intake manifold. than last pic can't figure out where the nipple on the black tank thing goes to? Maybe the black tank thing runs to the intake manifold or?
Old Jun 19, 2013 | 09:53 AM
Fliptard's Avatar
that black box, one line runs to a hard line, where your gas line comes up, on the firewall behind the motor. A smaller line runs from the black box to a purge solenoid on the right back side of the intake manifold. This solenoid has a plug from the wire harness, hose from intake manifold to it, and a hose from the black box. 3 thing total that hook to it. It suppose to have 1 10mm bolt that bolts it to the top of the manifold.
It's Number 9 in this picture
Old Jun 19, 2013 | 09:55 AM
Fliptard's Avatar
THis picture shows where all your coolant/water hoses run the correct way
Old Jun 19, 2013 | 10:02 AM
JDM3JDude's Avatar
Thanks alot bro!!!
EFProjectHatch
May 12, 2015 06:25 PM
MugenTGZ
May 22, 2013 01:57 AM
LSTurbo23
Mar 3, 2011 04:46 AM
9000rpms
Sep 27, 2006 08:19 AM
adictionbass
Jan 18, 2005 01:53 PM
