shifter cable question
Old Jun 18, 2013 | 06:25 AM
leon phelps's Avatar
Default shifter cable question
Hello,
been posting here with little luck.
basically got an 02 honda that has been sitting a long time. close to 10 years.
would not crank, figured it out. shifter cable is pulling out at the transmission.
if I push it in, the car will shift one time then will not go back to park.
any idea how this is supposed to stat together?
thanks in advance.
Old Jun 18, 2013 | 06:46 AM
Mishako129's Avatar
Default Re: shifter cable question
Are you sure that is your problem? If the car is off usually it won't let you change gears or start the car, it has to be in either N or P to start it too.
Unbolt it and have someone change the gears (this with the car battery in the ON position) and look at it see if it moves the mechanism. But first see if you can actually shift gears; put the car to the ON position and then try, it should work.
Maybe you need to JB weld that thing back on. On my 91' accord that things made of aluminum and won't break like that plastic does. If mine ever did break I am sure it would cause some problems though. You gotta take it off and replace it would be your best solution. JB weld may work for a while but you'll have to do a good job at applying it.
Old Jun 18, 2013 | 09:11 AM
with the bracket bolted to the trans, the cable definitely moves. It will push the cable out of the bracket, not the cable in the transmission.
car will start with shifter in park and the cable pushed all the way into the trans.
Old Jun 18, 2013 | 09:25 AM
sleepyaccord96's Avatar
jesus christ how many miles are on it?? if it has been sitting for that long that would mean it was only ever used for what maybe 1 or 2 years total!
post pics of the car please i really wanna see it!
Old Jun 18, 2013 | 12:19 PM
Old Jun 18, 2013 | 12:30 PM
Mishako129's Avatar
I know that's what I thought, why would somebody leave a car like that just sitting for so long!
I saw a coupe cb7 accord with leather interior the other day and it made my mouth water. Just putting that out there I know the Honda peeps on here like to hear of such things, it gets the juices flowing.
EDIT: By the way I am a Christian so would you please not take the name of our Lord in vain? That name is not to be abused like that, it is a powerful name, all powerful. Powerful not in the religious connotation but in the spiritual/mystical one.
Old Jun 18, 2013 | 02:07 PM
NZXTInerTia's Avatar
Oh lord. STOP. Its the internet, if you don't want to hear something ignore it.
Old Jun 18, 2013 | 03:55 PM
hope you feel better now.
friend got in an accident dui, served some time to get out and find body shop guy was in jail. friend moved on then forgot about the car. next he told me I could have it if I could get it out for storage.
Old Jun 19, 2013 | 04:55 AM
broke at the clamp on the trans side. damn plastics.
blackZC (W)
Nov 12, 2019 03:05 PM
lancemah
10
Aug 14, 2013 05:46 PM
Mishako129
Sep 6, 2012 03:14 PM
honey mead
Aug 13, 2006 03:56 PM
gumbysix
Jul 2, 2002 11:16 AM
