500-600hp h22 build
Hey all
I'm building up my h22 now. The bottom end is on the way to golden eagle now. I'm planning on running the garret GTX3076 with ID 2000'S injectors. My question is what fuel pump should I be running? I'd like to keep the intank theme uf possible and I'm currently running a walboro 255. This will be on pump gas. Also what wastegate should I run? Tial 44? Dual tial? Any help would be great. Its going in my 99 prelude
pump gas 600hp gtx3076? Pull the reins back and do some more research.
A walbro 255 can just about make what ever you want on pump gas. A new Walbro 400 will definitely be able to.
Amazing info thanks guys! So opinion time gtx3576 or pt6262 ball bearing? It will see track use but daily for sure. I drive with a light foot (granny style) on the street so a late boost climb is ok.
AEM 320lph fuel pump and if you are eventually gonna go E85 I know they just released a new version of the same pump that is 100% compatible with Ethanol, Methanol and Gasoline.
yeah just got off the phone with my tuner and he reccomended a 320lph deatschwerks fuel pump. deatschwerks 1300cc injectors and a garrett gtx3576 .82ar to get me close to the 600hp mark. and said water/meth would def get me over. thank you guys and girls for all the advice as most of it was spot on.
Last 5 years was on a stock sleeve H-series. 1300cc deash werk injectors, walbro 400 pump, tuned on hondata with a Borg Warner s259 70ar. Put down 559whp and 420tq. 74mm skunk2 throttle body ge intake.
