noise while driving
Old Jun 13, 2013 | 06:11 AM
cred1983's Avatar
Default noise while driving
I have a 99 civic ex and have noise while in idle and driving, goes away when I press in the clutch. replaced clutch and bearings but is still there. Any thoughts on what this is?
Old Jun 13, 2013 | 06:15 AM
Chris Westlund's Avatar
Default Re: noise while driving
No idea. Be more descriptive, Are we talking about a grinding noise? Whirring? High pitched whine? Ticking? Knocking?
Old Jun 17, 2013 | 06:53 AM
cred1983's Avatar
I think its more of a ticking or knocking. But like I said it goes away when the clutch is pressed in and seems to be coming around the transmission area. Don't have any problems with shifting or anything just a noise that seems more noticeable in 1st 2nd and 3rd gear. If I let out on the clutch hard in 1st and 2nd I don't hear the noise but do in 3rd.
Old Jun 17, 2013 | 08:00 AM
Joshka89's Avatar
What RPMs?
Have you checked for an exhaust leak?
Old Jun 18, 2013 | 01:30 AM
Buckshot870's Avatar
I don't think it's an exhaust leak, considering it stops when pressing IN the clutch. Could possibly be the release bearing?
Old Jun 18, 2013 | 05:10 AM
kyden's Avatar
which bearing did you replace? throw out bearing? you probably have a bad bearing internal to the transmission.
Old Jun 18, 2013 | 08:00 AM
instrument's Avatar
Did you resurface flywheel when you replaced clutch?
Old Jun 18, 2013 | 08:34 AM
sleepyaccord96's Avatar
throw out bearing no good !
will it do it at an idle? if you barely touch your foot on the clutch does the noise go away? if so you need a new TOB
Old Jun 18, 2013 | 08:35 AM
could also be the famous ISB going out
Old Jun 18, 2013 | 10:52 AM
jdmcx's Avatar
Icon6 Re: noise while driving
Could be 2 things: the throwout bearing, or input shaft bearing.
1.
This is how to diagnose it.....
-Start your car.
-Roll up the windows, turn the radio off, and turn the blower motor for the AC/heater off.
-put the car into neutral, and press in the clutch
---- if you hear the noise now, it is the THROWOUT BEARING. If you release the clutch, the noise should go away
2.
-Start your car.
-put the car into neutral, and take your foot off the clutch pedal
---- if you hear the noise now, it is the INPUT SHAFT BEARING. if you press in the clutch, the noise should go away.
Tyler Harteau
Jan 4, 2021 08:45 PM
usdmed9
May 17, 2011 10:46 AM
fatsheep
13
Jul 8, 2010 01:02 PM
b0yg0tskills
Honda Civic (2001 - 2005)
11
Mar 31, 2010 04:43 AM
93accordEX
Feb 2, 2010 04:40 AM
