Which injector seals (ID1000 + d16y8 manifold)
Old Jun 12, 2013 | 10:36 AM
tron_'s Avatar
10 Year Member
Default Which injector seals (ID1000 + d16y8 manifold)
First off, I already searched and found some similar information in this thread:
https://honda-tech.com/forums/forced-induction-16/id-siemens-thin-long-injector-b-series-3026226/
I put some ID1000s into my Civic which is running a d16y8 intake manifold. The problem I am having is that although the injectors are spaced correctly using the aluminum top hats I recieved from Evans Tuning, the injectors are too thin to properly seal in the intake manifold.
Is there an injector seal that I can get which will properly seal the space between the injector and the intake manifold? I did not have this problem with my FIC 850cc/min injectors since they were "fatter" and did not have any issue with leaking from around the intake manifold injector seals.
Old Jun 12, 2013 | 07:33 PM
artie89's Avatar
Default Re: Which injector seals (ID1000 + d16y8 manifold)
you need to order these washers they will keep the injectors from going to far in the intake manifold http://www.xenocron.com/washer-set-f...ors-p-295.html
Old Jun 12, 2013 | 08:29 PM
4dvti's Avatar
Will I need these for an oem b16a2 manifold or is the only way to find out by fitting them?
cheers
Old Jun 13, 2013 | 06:57 AM
tron_'s Avatar
10 Year Member
Do these washers go between the seal and the intake manifold? Although these prevent the injector from "sinking" will I need a different seal so the injector will not be "loose?"
Thanks for the reply.
Old Jun 13, 2013 | 09:14 AM
artie89's Avatar
the washers go around the bottom of the injectors and no you do not need a different seal just use the stock one
Old Jun 13, 2013 | 11:00 AM
tron_'s Avatar
10 Year Member
Great, thanks a bunch man
GsrRussell
Apr 14, 2008 11:34 AM
Mike1486
May 27, 2005 01:10 PM
egturbo
Feb 5, 2004 12:32 PM
TurboB18C1
Oct 9, 2002 10:56 AM
austrian type-R
Oct 3, 2002 09:43 AM
