b-20 build
Old Jun 10, 2013 | 05:49 PM
newbiemech's Avatar
Icon6 b-20 build
So im going to be building a b20 w/ turbo from the ground up. And thus far I have found that dart makes a performance block. So I guess my first question is there any other company that builds honda engine blocks, and how do they compare? And what would the best(strongest) crank, rod, and piston combination to use? Im not looking for the cheapest or easiest way to complete the build cause that will only lead to weakness.
Old Jun 10, 2013 | 06:08 PM
grumblemarc's Avatar
The Grumpiest
Default Re: b-20 build
So you don't sound like you're pipe dreaming or window shopping, how about we list something simple, like a power goal?
Old Jun 10, 2013 | 06:34 PM
newbiemech's Avatar
600HP is the very least I would be happy with but I think 750HP would be perfect(if possible). I didnt mention this before but I dont necessarily want this to be a daily driver but I dont want to have to trailer this from A to B either when I bring her out
Old Jun 10, 2013 | 06:38 PM
doood's Avatar
been there done that
- look at build threads in forced induction forum
- find one you like and makes the power you want
- copy it
yes, it's that easy.
Old Jun 10, 2013 | 06:46 PM
newbiemech's Avatar
Thanks but I want a collaboration of ideas so im left with making the decisions and im in no hurry so ill stick with my post but if you have any ideas ill be happy to take them into consideration
Old Jun 10, 2013 | 07:00 PM
doood's Avatar
why?
there's nothing new or groundbreaking going on here. everything that can be done, has been done. why would you trust the random OPINIONS of others on what *may* work or may not because it's what they heard or their cousin's brother's uncle's cell mate said it was da bomb, when you can look at the FACTS of what actually works?
it's obvious you dont know much about these motors, with your mention of a dart block that NOBODY uses. so how will you know whether someone giving you their opinion is full of **** or not?
Old Jun 10, 2013 | 07:36 PM
newbiemech's Avatar
I see your point. its a valid one and I have been browsing those posts but I need 2 posts to become a permanent member or whatever they call it and this seemed like a relevant topic for me to start with. And I figured the opinions of many coupled with careful research of those opinions will help me make the best decision. From what I have noticed people on here seem to be more than happy to ridicule others ideas if its wrong. And from what ive heard people dont use the dart block because its a little over 2 grand, but if you know of a company that makes a stronger block do-tell.
Old Jun 10, 2013 | 08:25 PM
Tyler Dirden's Avatar
I am Jack's...
You just got the regular beat down. From the regular beaters at that.
Dart is a different animal, for different goals. It has a taller deck that allows for a greater rod ratio which is very important in high rpm breathing (HP production), not for at all the adverage build. Custom rod length, pistons etc..
A Golden Eagle sleeved block is about the (gold standard) for anything 500+. It'll run about $1500. and is virtually indestructable (tuned properly), at any power level to 1300HP they claim and hold reccords everywhere.
IMO (in my opinion), stock crank to 700hp. ANYBODIE'S 4130 rods will work at your desired power and ARP stud it top and bottom.
DOOD is wrong about "nothing new or groundbreaking going on here". There are many threads that have a hint of something new going on. You have to be smart enough to see it or know what your looking for. I have posted several NEW ways/ things for everyone to see, along with a current thread on high power nitrous use. There are awesome resources here if you can sift through the BS.
Old Jun 10, 2013 | 08:47 PM
newbiemech's Avatar
Thank you for that.
Old Jun 11, 2013 | 05:45 AM
doood's Avatar
what exactly is new or groundbreaking that you're referring to? your cut valve cover with the **** on the end?
people have been making big power with nitrous for years as evidenced in your thread. they all bring up valid points on it's limitations. the fastest honda guys in the world arent using it. what's so different about what you want to do?
Old Jun 11, 2013 | 06:45 AM
The Grumpiest
As technology advances people may be pushing the envelope of what has already been done but no one is doing anything entirely new with these cars.
krysted9354
14
Jun 18, 2009 10:21 PM
dc4_wHORE
Sep 14, 2008 08:35 PM
wesley_925
Mar 22, 2008 03:04 AM
prjctwhteg
Oct 21, 2006 01:53 PM
Bullet50
Sep 17, 2002 02:30 AM
