99 civic si running rich
hello,
My civic is getting some crazy 10mpg. Its running far too rich and isnt even showing a check engine light. It loves to lag when I try to acclerate. It idles pretty low and occasionally stalls out. I've recently fixed some spit 02 wires with solder and installed the spark plug non-foulers to the rear o2 sensor to compensate for no cat. I haven't had a cat and I was getting better mpg without the non-foulers. New plugs, wires, cap rotor, tps and everything...
Could be a screwed anti-knock sensor?
If i'm not mistaken it will increase the amount of fuel coming in to prevent detonation. Or is that the newer technology and these are timing?
Also check the timing.
What about your injectors.
If you truly think its running too rich you need to check your fuel pressure at the least with a gauge. Have you checked your plugs to see if one or all are fouled? Does your enginehave a thermostat? I would still hook up a scanner to see if you have any pending codes?
jdm_vtec
May 19, 2007 06:31 PM
