How to add power steering?
Old Jun 3, 2013 | 08:20 PM
JakeJDM's Avatar
Default How to add power steering?
I was looking into buying an ek, but it doesn't have power steering. I prefer having power steering so i was wondering how i would go about adding it if I do decide to buy this car.
Old Jun 5, 2013 | 08:54 AM
Shmallow's Avatar
Default Re: How to add power steering?
go to the junk yard and buy all the parts associated with the PS system. bolt them on and fill it up with fluid.
most of it:
-pump
-pump bracket
-resevior
-resevior mount bracket
-rack
-various pipes and hoses
-belt
-fasteners, clips and other small brackets
it wouldn't be a bad idea to get new rack boots and tie-rod ends while you're at it. also, most of the clips may break if you pull this from the junk yard so you'll need to get those from honda.
fair warning, there is a lot of work involved in doing this "conversion." it's also likely to cost you a fair amount of cash even with discounted, used parts. most folks would just buy a car with P/S equipped.
Old Jun 6, 2013 | 10:09 AM
JakeJDM's Avatar
Ok thanks for the help. I'm going to get one with power steering already then, seems like a much better idea.
Old Jun 7, 2013 | 09:56 AM
dfarmer0033's Avatar
Step one : Remove resevior cap
Step two : Pour in fluid
Step three : Replace reservior cap
J/K source the parts at a local junkyard or you can try and find then on car-part.com most junkyards will ship if it is to far to drive.
Old Jun 8, 2013 | 12:13 PM
HondaPartsHero's Avatar
Technical Hero
It's not hard, I got the full thing off Craigslist for $100
http://repo.jackmoves.com/v/erik/album106/album119/
Old Jun 8, 2013 | 12:25 PM
Black R's Avatar
25 Year Member
Is the subframe different for ps vs manual rack ek's?
I know on EF's it's different and you can't use a manual subframe with a ps rack...
Old Jun 9, 2013 | 03:05 AM
Technical Hero
They're the same. I used that link exactly. Used my same subframe and everything bolts up great.
irollerblade
Nov 7, 2007 10:04 AM
ahron
Jul 18, 2007 03:50 PM
nextgtr
Aug 20, 2006 12:38 PM
efdriver
Apr 8, 2003 01:25 PM
