HELP!!! 01 Accord w/ F20B swap battery drain
Old Jun 3, 2013 | 07:55 AM
nine23's Avatar
Default HELP!!! 01 Accord w/ F20B swap battery drain
I just swapped a F20B in my accord from a F23A4 ULev with the F20B ECU and everything starts up and runs but I am getting a 12.5 drain on the battery when the ignition is not on.
i went through all of the fuses under the hood and on both sides of the dash and i still have have a 12.5 volt draw.... any help on possible relays bad? I unhooked the ecu, starter, and alternator and i still have a 12.5 draw...so i unhooked the power wire to the under hood fuse box and the draw went away so thats why im thinking its a relay stuck on... fuel pump still turns on when i turn the key to the on position. Any help is greatly appriciated!!!
Old Jun 3, 2013 | 07:08 PM
nine23's Avatar
Default Re: HELP!!! 01 Accord w/ F20B swap battery drain
Anyone?
Old Jun 3, 2013 | 11:31 PM
holmesnmanny's Avatar
I'm not sure what a 12.5 volt draw means.
If you go to youtube and search for "parasitic drain auto" you'll get some howto's on how to test for a parasitic drain if that's what you have.
Old Jun 4, 2013 | 03:49 AM
nine23's Avatar
I have already tested all the fuses....
Old Jun 4, 2013 | 05:29 AM
lazlong's Avatar
Did you test the relays tho? Test the relays and replace any bad ones. If no bad relays, then replace the under-hood fuse/relay box.
Old Jun 4, 2013 | 06:17 AM
nine23's Avatar
i did pull a couple relays from under the steering wheel to see if that would take the draw away but i didnt have any effect.... does anyone know where and how many relay i have to check?
Old Jun 4, 2013 | 06:19 AM
nine23's Avatar
it means when i disconnect the neg terminal and put the tester on the neg terminal and the neg cable im getting a -12.6 on the reader
Old Jun 4, 2013 | 06:43 AM
lazlong's Avatar
Check all the relays in the under-hood box first.
Old Jun 4, 2013 | 06:50 AM
nine23's Avatar
yeah that was my first check
Old Jun 4, 2013 | 07:09 AM
lazlong's Avatar
Now I'm thinking the under-hood box itself has an open.
Old Jun 4, 2013 | 07:26 AM
nine23's Avatar
yeah cause when i would take the power wire off the under hood fuse box it the drain would go away... what would you suggest my next move would be?
Old Jun 5, 2013 | 07:51 AM
nine23's Avatar
so we went through and continued unplugging plugs connected from the harness to the the motor and nothing changed last night..... the only rewiring that i can think of that we did for the swap was to change the plug for the dizzy from 4-8 prong and we had to switch the prong on the ecu plug so that we could get the fuel pump to work with the f20b ecu after trying to start it with f23 ecu.... I dont know if it could be the main relay?! im running out of options to check..... i have done numerous google searches and forum searches and it seems like there isnt anyone that has had this problem but i still believe someone has ran into this before! (possibly on an H22 swap??) please if anyone has any suggestions let me know!!!! thanks in adance!
Lantorax
Apr 18, 2018 02:36 PM
Alex Odushkin
Nov 15, 2017 07:50 PM
thefew
Jul 30, 2013 07:45 PM
nine23
Engine Management and Tuning
Jun 10, 2013 11:14 AM
Bancas
Feb 5, 2013 03:13 AM
