D15B Timing belt.
Old Jun 2, 2013 | 11:03 PM
DENNO's Avatar
Default D15B Timing belt.
I need some advice, my D15B Motor keeps on breaking the timing belt. i have changed it 3 times i a span of 5 months what could be the problem
Old Jun 2, 2013 | 11:05 PM
holmesnmanny's Avatar
Default Re: D15B Timing belt.
You're in the wrong forum.
Old Jun 3, 2013 | 12:46 AM
MAD_MIKE's Avatar
MM Gruppe B
True, how does the Civic crowd get lost here in Accord land? Forums are not even next to each other*shrug*.
DENNO a few things could be causing your belt to snap.
  • Incorrect installation. Too much tension on the belt will put undo wear on it. Timing belts just need the slack taken out, they do not stretch like V or serpentine belts.
  • Failing water pump or tensioner pulley placing stress on the belt causing undo stress.
  • Subpar components, belts/tensioner pulley/waterpump, that are failing cause they are crap.
dleccord
Apr 13, 2020 08:03 AM
Alan Roberts
Dec 10, 2018 08:05 PM
VegaS10
May 20, 2013 12:05 PM
TravisCadello
17
Apr 18, 2009 06:18 AM
honda94accord
Apr 10, 2007 05:39 AM
