honda crx blown clutch
hi i have a crx hf, i have a question and i need help. ok well my clutch went out. when i start my car i have to keep the clutch pedal to the floor to keep it running even in neutral and even in gear. the car wont move in first gear it wont move at all but when i throw it in second or third it wants to move. the question is it just my clutch thats blown or is it my tranny too? can some one get back to me on this. thanks
You have to hold the pedal to keep it running? Does it bog dow. If you let out?
If so it is engaged and should move your car,
I understand the car not moving because of a bad clutch but it should idle fine especially in neutral
Or if it don't want to run because its bogging down when you hold it, its not disengaged and should move the car, but won't stop without killing it.
have u tried shifting it in gears while the cars off? If u can do that ur trans is fine. How longs it been since u replaced the clutch anyway? It wouldnt hurt to do it.
FR-MOB: ThE bEe GuY
Oct 19, 2002 10:11 PM
