550whp @ 16 psi stock block h23a
my friend André tested that engine pretty hard
still runs, made many hours of dyno
stock block right from jaman imports, turbo pt6262, 8 injector ID2000 driven by a p28, on methanol fuel
Only 2 things allowing this much boost without failure.... meth and a great tune
FB H23AV Blue Top 473 hp 373 trq, pump 15 psi SC61.
I dont know anything about methanol but it must be made out of unicorn tears or something, 550whp on a 6262 @ 15psi is unheard of... Im skeptical to say the least. Track times please!
OK...Is it running pump gas with supplementary methanol injection? or running straight methanol as its primary fuel source?
Im familiar with meth injection, had a kit for my s2k. I was under the impression it was running straight methanol...
the motor is completly stock head to block... 10.6,1 comp ratio,AHR ported intake, AHR manifold,AHR intercooler. he run methanol fuel,,,on the dyno only 4 injectors was used
slammedbbs
Jun 6, 2011 09:32 AM
