Honda CR-V & Element 2WD & 4WD Element & CR-V
SWAP b18c1 in CR-v 1 gen AWD 5 spd
Old May 30, 2013 | 11:18 AM
sh4k3r's Avatar
Default SWAP b18c1 in CR-v 1 gen AWD 5 spd
What should I do to swap b18c1 in CR-V ?
Is there something specific ?!
Old May 30, 2013 | 01:22 PM
Sticker Bomb's Avatar
Default Re: SWAP b18c1 in CR-v 1 gen AWD 5 spd
The engine will bolt right in with no mods needed really, but you will need some new parts to make it work. You will swap over your clutch, flywheel, alternator, power steering pump, A/C compressor, engine mounts.
You are going to need a OBD2 ECU that has vtec or a OBD1 ECU with a conversion harness, run wiring to from the vtec switch to the ECU, B18C rad hoses as they are different then a B18/B20, engine harness for that engine.
I'm swapping a ITR engine into my CRV soon, after I blow up the B20 from turboing it lol.
It's not to hard to do, just takes more time because you need to add a few things.
Siouxbie
Aug 14, 2018 06:23 PM
honda1612
Apr 12, 2016 09:55 PM
cintron
15
Oct 17, 2008 12:21 PM
Twilight
Jan 9, 2006 06:42 AM
hondarookie10
Oct 26, 2003 06:14 PM
