need advice swaping a vtec b20.
Old Apr 12, 2016 | 11:17 AM
honda1612's Avatar
Default need advice swaping a vtec b20.
I have a wrecked 2000 si with a running vtec b20 and a lx with a shot d16y7. as bad as I hate to i need to swap the b20 to the lx. I am by no means a mechanic so I would probably pay to have it done. I was just wondering what needs to swap along with the engine? (Wiring harness, shifter linkage, etc..) And just a ruff number on what labor cost would be.
Old Apr 12, 2016 | 09:55 PM
2kdrift's Avatar
Default Re: need advice swaping a vtec b20.
drivers side mount bracket, shift linkage, transmission, axels and ecu, you also need to wire in vtec or swap the engine harness... is what comes to mind
im sure there is a writeup somewhere if u took the time to search. I did a similar swap about 5 years ago and I was able to find all the info I needed and did all the work myself
KillAhKev
May 30, 2011 07:10 PM
CPreston
24
Feb 14, 2010 01:16 PM
VitesseCRX
Oct 13, 2002 04:39 PM
EURO_CL9
Oct 8, 2001 02:14 PM
