tuning/break in
Old May 29, 2013 | 09:33 PM
jhotboy2nv's Avatar
Default tuning/break in
i have a fresh built ls/vtec the issue im having is that im running rc 310 injectors and im using a stock computer can i get a base map for now to just break in the motor until i dyno the car . i dont wanna just take it to the dyno now. so lmk my best options
Old May 29, 2013 | 09:37 PM
doood's Avatar
been there done that
Default Re: tuning/break in
did you not read the link i gave you in your other thread?
Old May 29, 2013 | 09:41 PM
mtber's Avatar
Your best option maybe to run the car on stock injectors with a stock ecu at partial throttle until the car can be tuned.
Post more information about the entire engine setup and specifically what stock ecu you have for a definitive answer.
Old May 29, 2013 | 09:54 PM
jhotboy2nv's Avatar
ls/vtec b16 pistons b16 head skunk 2 cams aem cam gears skunk2 intake manifold/throttle body dual springs and retainers ecu is a jdm gsr p72
Old May 30, 2013 | 09:25 AM
cvcrcr99's Avatar
Cool, so when you run the wrong injectors, don't ask why fuel flooded your conbustion chambers, leaked into your oil, caused scarring/bearing issues. Gas eliminates lubrication properties in oil.
The ECU thinks 240cc injector, open for XX of time under XXX load. You change the size of the injector, but nothing with the ECU. I expect fantastic results.
Old May 30, 2013 | 09:26 AM
JuggerNaut-CTR's Avatar
Cant say im shocked op started ANOTHER thread
Old May 30, 2013 | 09:28 AM
TypeRfit's Avatar
RESIDENT
Is that Jeremy Clarkson Jugger?
jhotboy2nv's Avatar
well ima downgrade for now
Old May 30, 2013 | 09:37 AM
I can see the resemblance...but no, Steve Martin "Dead Men Don't Wear Plaid"
Old May 30, 2013 | 09:40 AM
TypeRfit's Avatar
RESIDENT
I see.
Old May 30, 2013 | 09:42 AM
^Sooo.....turtle soup eh (?)
Old May 30, 2013 | 09:44 AM
TypeRfit's Avatar
RESIDENT
Hahaha, yeah. Have some Filipino friends and their grandma makes it. Wasn't bad at all.
Crazyycivic98
Engine Management and Tuning
Apr 20, 2015 08:44 AM
bscotti
18
Jun 26, 2012 03:53 PM
GEN2 LS
Apr 4, 2012 02:57 PM
em1_sir
12
Oct 18, 2007 08:01 PM
sleepencivic
Jun 7, 2006 01:11 PM
