Idle Problem D16z6, IACV and FITV good
Old May 26, 2013 | 11:38 AM
Luis0n's Avatar
Icon6 Idle Problem D16z6, IACV and FITV good
Hi.
I have some problem with the idle of my car, i have a honda civic 95 d16z6.
The car hold in 1500 rpm, i cleanup the IACV and the FITV with the help of this thread : https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-fix-your-idleing-woes-fitv-iacv-2153910/
But i have the same issue.
i dont have vacuum leak. But i can see this problem with my PCV valve.
My PCV valve its brand new, and the vacuum line its new.
Check this out, someone its bad?? i dont know what happend.
Thanks
Old May 26, 2013 | 11:41 AM
B_Swapped93's Avatar
Default Re: Idle Problem D16z6, IACV and FITV good
why does the hose "taper in" ?. looks like an oil leak but I don't see the problem ?
and here try this http://www.team-integra.net/forum/bl...peed-gen3.html
Old May 26, 2013 | 11:58 AM
Luis0n's Avatar
B_Swapped93
The manifold suck air with the vacuum of the PCV. i dont know if this is normal that is look like a taper in.
yes, in the PCV valve have oil leak but i dont know why.
The principal problem the idle, this hold at 1500 rpm all time, just if a drive my car arount 15 min or 30 min, this go to normal.
Old May 26, 2013 | 12:03 PM
b20VAngel's Avatar
open your fast idle valve and screw it back in probably got loose common over the years. it is over 15 years old. go to 3:45 on the time line to show you how to do it.
Old May 26, 2013 | 12:09 PM
Luis0n's Avatar
b20VAngel
I did That right now, but i have the same problem.
Old May 26, 2013 | 12:14 PM
b20VAngel's Avatar
the old mans trick is to use starter fluid to check hoses. spray one vacuum hose at a time and if the idle jumps up after you just sprayed a hose thats where your leak is and the air is coming from. also spray the manifold base to see if the gasket sealed right. other than that all i can imagine is your dizzy timing. move it back and forth check if it drops. last but not least is the idle adjustment bolt on the top of the throttle body use a flat head and start closing it and see if any changes happen. if any of those work disconnect your battery after to reset your ecu.
b20VAngel's Avatar
other than that i dont know. sorry lol.
Old May 26, 2013 | 12:17 PM
so the pcv valve is leaking....replace it or the box doesn't seem hard and consider that link I posted
Old May 26, 2013 | 12:50 PM
Luis0n's Avatar
B_Swapped93
If i do this of your link, what happend when my car go to normal operation, because i drive my card around of 15-30 min. go to normal, maybe more time lol.
Old May 26, 2013 | 12:57 PM
if it goes to normal after x amount of time that would point to your FITV what all did you do to it ?
Old May 26, 2013 | 03:23 PM
JKing106's Avatar
That PCV valve is probably gunked shut. Replace it, and both hoses running from the breather box to the intake manifold. That hose running from the PCV valve to the intake manifold has collapsed.
Old May 26, 2013 | 06:40 PM
Wdpfreak145's Avatar
The PCV valve is a check valve; it only lets air flow one way. Blow on the receiving end, it should flow through. Blow from the other side, the valve should block the air. Try soaking it in gasoline.
Otherwise, start checking for vacuum leaks with starting fluid. As you spray around the intake manifold, if your RPM's go up, the starting fluid is getting in. There's your leak.
Also make SURE that you clean the IACV thoroughly. I cleaned my IACV about 4 times when I first got my car and my problem wasn't solved until I let the IACV soak in brake parts cleaner.
Old Jun 20, 2013 | 10:53 AM
Luis0n's Avatar
I clean Up the IACV a lot of time with carbclean, but not work. the RPM holding to 1500.
Another thing, i need to start the car giving more Gas, this happend some times and i having the problem if idle
Other Day, the car turn on Perfect and not Idle Problem.
This Situation its bad, i dont know what happend.
Old Jun 20, 2013 | 12:29 PM
weezie41's Avatar
i was having the same problem with my d16z6 did everthing youve done and just so happen to check distriutor cap and thats what my problem was,havent had any priblems since,so check distriutor cap.
Old Nov 27, 2013 | 08:29 AM
Luis0n's Avatar
Hi, i have an update.
My distributor cap stop to work,, then i bought a new coil distributor because dont have enoght power or spark the old coil.
When i change the coil of the distributor cap all problems are solved.
Thanks anyways weezie41, i dont see your message but this solved my problems.
Luis0n
Aug 11, 2012 01:29 PM
jdm-ichiban
Jun 8, 2012 03:01 PM
martingouda
Nov 24, 2005 11:54 AM
Soccerking3000
Aug 5, 2004 05:57 PM
