What do i need to do to switch my 93 gsr motor into a 96 civic hatch????
Old Oct 23, 2002 | 04:58 PM
wickedxboi's Avatar
Default What do i need to do to switch my 93 gsr motor into a 96 civic hatch????
i have a b17a(93gsr)in my crx with hcp mounts and gsr spindles. the tranny is also cable. the shift linkage has been modified to fit my car(gsr). the wiring harness was converted to obd 1.
i was thinking of using some stock integra mounts, si rear bracket, integra throttle cable, and hasport hydro cable conversion(should i sell the my tranny and get a hydro? The one I have works perfect) i was going to use the harness off the crx (will that save me trouble? Since the civic is obd 2). should i get another shift linkage or modify it back to fit the civic? will the gsr spindles swap right over? Any info would help. thanks
Old Oct 29, 2002 | 09:45 AM
wickedxboi's Avatar
Default Re: What do i need to do to switch my 93 gsr motor into a 96 civic hatch???? (wickedxboi)
anyone?
Old Oct 29, 2002 | 10:03 AM
tonyxcom's Avatar
get a hydro tranny.
99 SI rear tranny bracket.
99 SI Driver side bracket.
Use your stock lower torque mounts on the civic.
Use your stock rear torque mounts on the civic.
Use the stock upper tranny mount/bracket on your civic.
Use the stock drivers side mount on your civic.
Any B-series A/C mount. (Delsol P54 if you want to keep AC)
Delsol, 99SI, DC Shiftlinkage and axles.
MUST USE 96-98 Engine Harness - EX preferred.
Correct Adapter to use whichever ecu you choose.
[Modified by tonyxcom, 7:04 PM 10/29/2002]
Old Oct 29, 2002 | 02:25 PM
wickedxboi's Avatar
Default Re: What do i need to do to switch my 93 gsr motor into a 96 civic hatch???? (tonyxcom)
thanks
lyzer227
Jul 6, 2009 01:44 PM
esurds
Jun 25, 2009 06:03 AM
Deanski
23
Mar 16, 2009 05:51 PM
hspoon
Feb 21, 2007 08:43 AM
tRex99
Jan 29, 2005 03:23 PM
