front suspension help!!!
Front passenger wheel moves back and forth when I pullor push on it. Not sure what this could be? And the steering arm that's attached moves with it. Could it be a ball joint or is the steering rack bad? Its on a 2000 civic ex..
My lugs are tight..LOL. I can grab bother sides of my wheel and pull it back and fourth. Took my wheel off everything looked fine can just move the hub assembly back and fourth not really any movement up and down. Driver side is tight no movement.
There a pain in the *** to be honest. best bet is take off the whole fork with hub and have a shop press the bearing out and new one in. whould be cheap since all the labor is done by you and there just pressing bearings out and in.
Originally Posted by markass420
OK thanks ill check that? Is that a fairly easy fix? Do I need to do any thing special to do the replacement?
Posted from Honda-tech.com App for Android
You said the steering arm moves with it. If you have a friend, have them move it back and forth and see whats not tight. if you see the axle move independent of the steering knuckle, then it's a bearing/hub.
boosh
Jun 9, 2008 05:05 AM
Mr. Vapor
Dec 5, 2002 05:29 PM
