b16 swap vacuum problem pls help
Old May 25, 2013 | 04:49 PM
ceearexx's Avatar
Default b16 swap vacuum problem pls help
Just finished a B16A swap into my 89 ef . I got the car to turn on and it idles fine drives fine but when I give it a little gas it has what sounds like a rev limiter like at 1200 rpms. But I can easily rev past that and drive it normal just gets alittle annoying getting out of first because it does that rev limit thing and make the car bog.
Ill post a video of how it sounds.
Also its running with the fpr vacuum off cause if l connect it the car will shut off.
I have a check engine for iacv I just replaced it with a known good one. Still have the cel.
Old May 25, 2013 | 06:29 PM
HEADS OR TAILS's Avatar
Default Re: b16 swap vacuum problem pls help
is your car a si model? if the car shuts off with the line connected you need to check fuel pressure and you might wanna try a different ecu and see if the code 14 goes away
Old May 25, 2013 | 06:34 PM
ceearexx's Avatar
Here is a video of how it sounds.
Old May 25, 2013 | 06:36 PM
ceearexx's Avatar
No it is a DX converted to mpfi obd1.
Ill try another ecu right now and let you know what it does.
Old May 25, 2013 | 06:54 PM
ceearexx's Avatar
just tried another ecu and same code 14 iacv. and changed the fpr and does the same when i connect it.
will a bad pcv valve cause this? or what else can it be?
Old May 25, 2013 | 07:17 PM
b20VAngel's Avatar
IACV wont do that! could be the dizzy i had a problem like that on my ef hatch once with a d15 it ended up being the camshaft sensor located inside the dizzy. you can get any other dizzy and just change the internals. not saying thats the problem but it was for me.
Old May 25, 2013 | 08:17 PM
ceearexx's Avatar
Could be because my rpms stop working out of no where maybe the distributor is bad.
Ill get another one tomorrow and see what happens.
Old May 26, 2013 | 06:08 AM
zrickety's Avatar
From what you've posted, it sounds like the wiring. There are a couple plugs that look the same as the IACV, same wire colors, you might have them switched. I think the knock sensor is one? You need to fix the CEL and connect the vacuum before it will run right.
bayron
Nov 16, 2008 05:14 AM
asmallsol
Aug 14, 2006 05:23 AM
dingusjt
May 6, 2003 09:56 AM
dropd4door
Apr 5, 2003 03:27 AM
STK B16
Feb 15, 2002 12:32 PM
