Hood Seal Required on 96-00 Civic?
Old May 23, 2013 | 10:26 PM
SportEL's Avatar
Default Hood Seal Required on 96-00 Civic?
Is the hood seal on the outer underside of the hood required? I took my old one off due to it's condition, and you can't notice anything amiss when it's not there. So now I wonder if I even require it.
Old May 24, 2013 | 04:54 AM
sleepyaccord96's Avatar
Default Re: Hood Seal Required on 96-00 Civic?
no it is not required.
removing it only makes you more jdm, less weight and it gives you the look and feel of a car straight outta tokyo!
^ i am kidding about that part but seriously No you do not need that rubber seal, it is nice to have one but if yours is damaged then it's ok to just remove it.
Old May 24, 2013 | 08:37 AM
NVturbo's Avatar
O.G. triple O.G.
your mpg will go from 38 to 20. Put it back on, at least a new one.
haha....j/k, I would replace it if I were you. Makes it easier to sell the car if everything is where it's supposed to be. Missing parts deter people from buying.
Old May 24, 2013 | 08:41 AM
^ true
but the jdm look and feel will be gone if the rubber is re installed...
^ lol
Old May 24, 2013 | 11:16 PM
SportEL's Avatar
I have been told that the seal is required for proper airflow to the radiator. Without the seal there, there is no low pressure zone behind the rad if air goes between the hood and grille or something like that.
That means the engine will run hotter.
Old May 25, 2013 | 06:28 AM
false ^
Old May 25, 2013 | 01:26 PM
NVturbo's Avatar
O.G. triple O.G.
From what I've seen, the only thing the seal does is stop water from spraying into the engine bay during a hand car wash. Other than that, it's main purpose is to maintain a tight seal of the hood once it's closed shut
Old May 25, 2013 | 01:53 PM
B_Swapped93's Avatar
true.
mandoski
Oct 7, 2018 12:47 PM
YEAH!
Jun 11, 2013 11:34 PM
GTijoejoe
Jan 29, 2011 08:24 AM
miguey310
19
Feb 5, 2010 05:31 PM
99EM1
53
Mar 20, 2007 09:03 PM
