98 Civic LX 4-door exhaust swap
From: Northwest Hills of, CT., United States of America
Hello all,
I have a 1998 Honda Civic LX 4-door 5-speed that I have been wanting to change the exhaust out for a while. The factory cat/manifold leaks and now smells in the car. The car has 180,000 miles on it and I do not want to spend a fortune to fix it. I did find this on ebay:
http://www.ebay.com/itm/150660179591?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D150660179591%26_rdc%3D1
Here is my question: I know you can swap over to an EX exhaust and you have to relocate the cat using an O2 sensor pigtail but the specific details to do the job I cannot find. On the cheap ebay parts it specifies 2/4 door.....I always thought exhaust from a 2-door would not fit a 4-door and vise versa. I realize this kit only has a test pipe and not a cat which I could buy after. Do you guys think this kit will fit? Any better suggestions for me? I need to get this job done soon, I have my daughter in the car and even though I put the air on recirculate I do not want to chance her breathing in the exhaust. I appreciate all of your help.
Thanks,
Thanks,
It will fit, you will need an O2 extension wire (cheap), you will need a new high flow cat (not so cheap), and you will need a new muffler (can be cheap).
I have been lucky in the past finding and using Magnaflow cats that are not to pricey and I would think being high flow is not so important in this case. Performance is not a huge issue on this car. Is there a reason you mentioned using a high flow cat specifically? Although I do hate the 4" muffler tip what would be the reason I would have to change the muffler?
You'll need a "high flow" cat because it's a lot easier to find a 2 1/4" high flow cat and have it welded in than it will be to find a "standard" cat that bolts in. You'll want a new muffler because the "N1 style" that comes with that exhaust will make your car sound like a rabid pack of bees trying to kill a water buffalo. I have basically the same exhaust (2.5" instead of 2.25"), with a welded in 2.5" cat, and a Thrush Turbo muffler ($30 at your local Autozone), and it sounds great, even to my 60+ year old, grew up driving BMW's mother.
I really think I will take the advise on the muffler. I am pretty sure I had a standard magnaflow cat welded and not bolted in the past. Is there a particular high flow cat you recommend? My last experience with a high flow cat allowed me to pass emissions once before I had to replace it with the standard cat. It no longer did what it was supposed to too allow me to pass.
I have a Magnaflow under my car. Granted, I don't have to go through emissions testing, so YMMV. If you can get a standard cat, go for it. There's no real benefit to a high flow cat other than calling it "high flow".
I appreciate all the help. I am trying to get all the parts I need together. I will need O2 extensions. They are available in 16" and 32" lengths....Any idea which one or two that I need to relocate the the O2 sensors?
Thank you for your help..How many o2 extensions do I need? 1 or 2? Is one of the stock wires long enough? That Thrush Turbo exhaust you bought....Did you buy it for a civic EX? or another Model? Thanks again!
Just one.
It's a muffler, not an exhaust. It isn't chassis specific. Just a generic muffler with an inlet size to match the piping you buy. Your local muffler shop will weld it on for you.
hondur
14
Aug 15, 2015 11:50 PM
aaronhume
Dec 3, 2010 05:22 PM
