97 del sol si engine harness
Hi there HT,
So I have a 1997 Del Sol SI engine harness and I'm missing the 2nd piece of the harness where it connects to the ecu. I was wondering if there's any other 2nd piece harness that is compatible to the 97 Del sol SI I can use and isn't hard to find. Thanks
Re: 97 del sol si engine harness
well I know the bay harness is identical to a honda hx
I found that out trying to find a damn alternator that fit
not sure if its different going into the car but Im guessing not it should be obd2-a
Seagull Management
A legit Canadian OBD2 civic uses a 3 wire alternator plug, US is a 4 wire square plug. '96 - '00 Canadian Civics don't have an ELD that's why.
you know I totally thought most Honda's had harnesses that unplugged on both sides
I thought it was a pretty cool feature especially when I was putting a new motor in :D
Seagull Management
It is, although you can still pull the one piece harness with the engine, it just requires removing the battery tray and feeding the harness out through the firewall.
b20delslow
07-25-2018 07:44 PM
stiffinEK
11-22-2009 04:49 AM
eghatch4sale
16
03-26-2006 06:57 PM
