Tial Q BOV open at idle...... help
removed an old kit from my car and installed a new turbo system. I have the Tial Q blow off valve but it seems that it is 100% open at idle. Some people have said that this is normal. However my old greddy type s didn't do this. Also I really don't like the fact that its sucking in un filtered air. Some people have added washers to stiff in the spring more. Other people say change the spring out. some people have changed the spring all to find out that it is then to stiff and promotes turbo chatter. Not good..... any advise on what I should do???? I cant believe tial did not made this product adjustable only by internal springs....
That is because it is a quality product. Using an adjustment nut to provide a dynamic change is a joke in itself when you think about how sensitive a BOV really is. The design to maintian barely enough pressure to stay closed at idle but to be able to vent very quickly as needed. Don't knock something that you are clearly too ignorant to figure out.
TiAL made a spring chart with different springs and vacuum correlations for a reason. It is called find out your vacuum at idle and purchase the correct spring. It is really that simple. When you add washers you actually change the pressure of the spring and restrict travel. It could cause early coil bind as it wasn't intended to do that by design...
hey man im not knocking it. obviously I have there products on my car. Just have been hearing that its hard to get the right spring for your cars vac measurement and trying to ask advise as to the best way to go about getting it right. Now I know. get a spring for my cars vacume measurement. thanks.
got wide
Oct 20, 2008 09:16 AM
JDMCRX
Jun 7, 2007 12:31 PM
