Installing timing belt b20/v
Old May 15, 2013 | 07:22 PM
joiv21's Avatar
Default Installing timing belt b20/v
I have a aftermarket pulley on my b20v and i need to remove it to replace the timing belt but the honda key doesnt fit the unorthodox pulley because the pulley isnt shaped like a hexagon like the hex key.? So what do i do? or do i HAVE to remove the pulley to replace timing belt any tricks?
Old May 15, 2013 | 07:29 PM
joiv21's Avatar
Default Re: Installing timing belt b20/v
bump it up
Old May 15, 2013 | 07:45 PM
jbpnoman's Avatar
Are you talking about the crank pulley? You don't need to remove that.
Old May 15, 2013 | 07:47 PM
DumpdEJ6's Avatar
I like the tuna here
It will need to be removed in order to get to the the lower timing belt cover. I've always taken the starter out and had someone brace either a ball joint separator or a lugnut wrench or something sturdy against the bolts on the flywheel, while I kick the **** out of the breaker bar attached to the crank bolt.
Alternatively, you could use an impact gun.
Old May 15, 2013 | 08:03 PM
joiv21's Avatar
Well my motor is out of the on a motor stand and it doesnt have the cover on. so im trying to put the belt on without having to remove my pulley cause i have no idea how to remove this aftermarket pulley.
Old May 15, 2013 | 08:06 PM
DumpdEJ6's Avatar
Well without a cover it should be easy to see the timing belt crank pulley, just slip the timing belt over the large crank pulley and there you go. Although I would really recommend putting the lower cover on, if you get a rock or something popping in there while you're driving, you might destroy your engine.
Old May 15, 2013 | 08:16 PM
joiv21's Avatar
right i plan on that but i dont see the difference whether i take the pulley off or leave it on it shouldnt make putting the timing belt on that much difficult. Is my belt to small or what? i used the same belt on my b16 so it shouldnt be to small .
Old May 15, 2013 | 09:07 PM
98civdx's Avatar
Master Detailer
The size of the belt has nothing to do with the crank pulley. The belt doesn't ride on it.
Old May 15, 2013 | 09:21 PM
jbpnoman's Avatar
The timing belt runs on the timing belt drive pulley.
The B20 block has a taller deck height than the B16A, and thus uses a longer timing belt. You want a P72 timing belt from a GSR/ITR.
Old May 16, 2013 | 05:15 AM
kyden's Avatar
impact gun.
Old May 16, 2013 | 05:35 AM
joiv21's Avatar
So ima need a p72 to belt from a Gsr.? Cool, that's the info I need can I get a part no? Or where do y'all think the best place is to get them, just my auto store?
Old May 16, 2013 | 06:50 AM
B_Swapped93's Avatar
The Honda dealer or get a gates "racing belt" same brand was OEM belt just tougher !. and yes just slide it over
crvglenn
Honda CR-V & Element
Aug 20, 2017 01:44 AM
Powered by VTEC
Jan 29, 2008 05:58 PM
virusiidx
Jan 6, 2005 06:38 PM
h46it
Mar 21, 2002 07:57 AM
Silude
Jun 4, 2001 08:31 PM
