Can I use a 5-bolt housing on a 4-bolt turbo/same A/R?
Just found out my Turbonetics T04B/T3 just took a **** on me and the CHRA is destroyed.. I just ordered a Precision 3254 T3/T4 turbo to replace it. This turbo comes with a .63 A/R 4-Bolt turbine housing.
Can I use my .63 A/R 5-bolt turbine housing from my turbonetics with my .63 A/R 4-bolt precision turbo? Will it even fit/bolt up?
If yes, would I need a rebalance? I honestly just built my downpipe and welded it with a 5-bolt flange and I have NO time to redo it.
http://www.ebay.com/itm/Precision-55mm-Turbo-3254-Journal-Bearing-T3-T4-470hp-63-A-R-4-Bolt-3254E-/290754765469?pt=Motors_Car_Truck_Parts_Accessories&hash=item43b255a29d&vxp=mtr
The exhaust housing are matched to their respective turbine wheel. So unless it is the same exhaust wheel in both, no you could not swap housings.
Edit: Was typing as TheShodan was posting... what he said.
Alright, thanks. I'll stop spamming the FI thread now. Just had to get a few issues figured out. Glad I decided to order a 4 bolt flange just in case!
biada1
Nov 28, 2006 12:53 PM
