lower strut bolt
Old May 12, 2013 | 10:13 AM
91 b20 integra's Avatar
Default lower strut bolt
I'm doing struts and springs in the civic but on the lower strut bolt, the rubber bushing seized to the bolt. Got it broken loose but half the bushing is stuck to the bolt preventing it from freeing. Anybody got a cool trick for this?
Old May 12, 2013 | 10:16 AM
B_Swapped93's Avatar
Default Re: lower strut bolt
burn it out.
Old May 12, 2013 | 10:56 AM
If I don't have a torch? Lol
Old May 12, 2013 | 10:58 AM
Marvin1985's Avatar
Get one!
I had to cut the nut on the other side and spread the shock fork a lil to get it off then get new bushings from dealer.
Old May 12, 2013 | 11:03 AM
Lol how much does a decent torch run? Are there any other tricks to free the bolt or is kill it with fire the answer?
Old May 12, 2013 | 11:37 AM
Lizardslap's Avatar
they dont come off and if you try and wrench it off with a breaker bar your just gonna snap the head off and still have it stuck
when / if you get it off grease the new bolt well before putting it back on
Old May 12, 2013 | 12:08 PM
andyz's Avatar
Cut off wheel
Old May 12, 2013 | 12:22 PM
Originally Posted by andyz
Cut off wheel
OP a tourch can run you 20-80 depends on what you want
Old May 18, 2013 | 02:16 PM
ended up cutting the bolt apart because heat didn't help lol
Old May 18, 2013 | 03:24 PM
andyz's Avatar
Once that bolt is sufficiently rusted to the inner sleeve of the bushing there's really no hope. It's really one piece of metal. If you get a solid grip on the bolt and don't snap it, you can bend the tabs on the control arm as the inner sleeve won't come thru.
Old May 18, 2013 | 03:27 PM
I've had to do that also took a angle grinder to it.
Old May 18, 2013 | 03:33 PM
tlarimer's Avatar
Sawzall is what I had to use, because it's what I had on hand
Si_chRis
14
May 27, 2007 09:05 AM
flip b18b
Jun 28, 2004 10:31 PM
boostin4drcivic
Apr 18, 2004 03:57 PM
unknown317
Jul 27, 2003 09:23 PM
b18bvudoo
Aug 16, 2001 08:14 AM
