Low cold idle, pulsaing fast idle when hot, outdoor temperature dependent
Old May 12, 2013 | 09:19 AM
KimvdLinde's Avatar
Default Low cold idle, pulsaing fast idle when hot, outdoor temperature dependent
When I start my engine, and especially when it is cold outside, my idle is almost non-existent and the engine will occasionally stop by itself. Once it gets warm, this problem resolves, but when it is relative hot outside, and the engine is warm, it start idling like crazy in a pulsating matter, basically runs up for a bit and drops down again. If I rev the engine at that time, it often idles better, sometimes within normal range, or at least not as fast as before. Ideas of what is going on?
Old May 12, 2013 | 10:33 AM
ED3 SEDAN-GSR's Avatar
Default Re: Low cold idle, pulsaing fast idle when hot, outdoor temperature dependent
I had the exact same issue on my gsr. Low cold idle and high pulsing warm idle. But i had the iacv and the fitv both unhooked. So i took both the iacv and the fitv off and cleaned them really well and hooked them up the way they should be and it stopped.
So what im sayin is clean the iacv and fitv and you should be good. And try rebleeding the coolant system.
Old May 12, 2013 | 09:09 PM
Son2BEHO's Avatar
I was thinking bleed coolant test tps clean iacv easy things first
Have you done any work on it before this problem?
Old May 12, 2013 | 09:35 PM
silkypillows's Avatar
common problem in Honda's with FITV's.
I agree to start with easy probable causes first, but these may shed some light on the subject.
Old Jun 29, 2013 | 01:40 PM
KimvdLinde's Avatar
Most of the issue was solved after I found a small leak in one of the vacuum hoses....
Azad_R
Oct 2, 2013 07:54 AM
kUrb3d
Aug 16, 2010 11:20 AM
EK45VTi
Dec 11, 2007 06:46 PM
Dawsonb17a
Jun 19, 2004 03:44 PM
