Fuel setup on drag kit?
I have a Drag III with inline fuel pump and stock injectors @ 8psi.
Can I run lower than a 12:1 fmu?
Has anyone tried this? Results on maybe a 10:1?
My search turned up no well thought out results.
i would go with a high flow in tank pump, smc, and dsm injectors. for about 300 dollars all together you can run higher than 8psi and not run almost 100 fuel psi.
my thoughts exactly. I have the same exact setup. Use the Intank fuel pump, dsm injectors, and the hondata s200. U can get rid of that silly FMU, and all the check valves (if you have them). and u probably can boost at least 10 to 12 psi.
gtowni3
Mar 17, 2004 07:59 PM
