Fuel setup on drag kit?
Old Oct 23, 2002 | 10:27 AM
jdmWONG's Avatar
Default Fuel setup on drag kit?
I have a Drag III with inline fuel pump and stock injectors @ 8psi.
Can I run lower than a 12:1 fmu?
Has anyone tried this? Results on maybe a 10:1?
My search turned up no well thought out results.
Old Oct 23, 2002 | 10:39 AM
TeStUdO's Avatar
Default Re: Fuel setup on drag kit? (Blow'N'CRX)
i would go with a high flow in tank pump, smc, and dsm injectors. for about 300 dollars all together you can run higher than 8psi and not run almost 100 fuel psi.
Old Oct 23, 2002 | 04:19 PM
Tegman88's Avatar
go with hondata s200, walbro hp intank pump and a set of dsm 450's...i think you might run into problems just running 10:1 fmu with stock injectors and inline pump
Old Oct 23, 2002 | 06:28 PM
WONG FRIED RICE's Avatar
Default Re: Fuel setup on drag kit? (Tegman88)
my thoughts exactly. I have the same exact setup. Use the Intank fuel pump, dsm injectors, and the hondata s200. U can get rid of that silly FMU, and all the check valves (if you have them). and u probably can boost at least 10 to 12 psi.
gtowni3
Mar 17, 2004 07:59 PM
untitled
Jan 7, 2004 03:29 AM
Integra808
Aug 1, 2003 12:22 AM
gsr sol
Aug 29, 2002 09:18 AM
SIK IN DA HED
Jun 29, 2001 12:45 AM
