no ignition power when key is on
Old Oct 23, 2002 | 10:02 AM
Hondasaurs's Avatar
Default no ignition power when key is on
i turn the key to the on position and it has no power, the car will crank but not stay running, it dies immediately, what could cause this and what can i do to fix it. I tried replacing the key cylinder and that did nothing, the problem still exists.
Old Oct 23, 2002 | 01:44 PM
Perfectionist's Avatar
Default Re: no ignition power when key is on (ZC_CRX)
Did you replaced the key cylinder, or the contact part of the ignition switch? Does anything light up with the key in the run position? If not, the contact part of the ignition switch needs replacing.
Old Oct 23, 2002 | 06:44 PM
Hondasaurs's Avatar
Default Re: no ignition power when key is on (Perfectionist)
i just fixed it...i bipassed the igniton with a relay and toggle switch and wired in a push button start
Old Oct 24, 2002 | 08:03 AM
cinq's Avatar
just get a new ignition switch..and you will be ok.
Barf Hat
Oct 9, 2019 05:45 AM
fazalabbas
Jan 5, 2019 10:36 PM
cthack76
Apr 19, 2012 03:31 AM
GoldCoin
Oct 24, 2007 12:09 AM
