Key stuck in the ignition
Old Feb 10, 2012 | 11:35 AM
Barf Hat's Avatar
Default Key stuck in the ignition
Hey everyone I have a 95 integra and my key is stuck in the ignition. My ignition switch fried on me a while back, and I had to replace it. Here is the problem though with the new ignition switch the key will not turn back far enough to let me get the key out. Has anyone had a problem like this before? If you guys need anymore info just ask.
Old Feb 10, 2012 | 11:49 AM
B20ztek's Avatar
Default Re: Key stuck in the ignition
Is this the first time its happened? In all Hondas you have to make sure not to just yank the keys out. Always gently turn it, and move the steering wheel back and forth, also try starting the car, then push it in and turn back.
Old Feb 10, 2012 | 12:35 PM
Barf Hat's Avatar
Yeah I know that, but here is the thing I bought the new ignition switch from acura and to actually be able to use the ignition I had to first put the key in the ignition and then install the switch. The new switch doesnt let the key turn far enough to let me take the key out of the ignition. The real question is the dealer and only has one part number for the ignition switch. The switch that they gave me is the wrong one for my car, and I cant find the right one. Does anyone know what the part number is for the correct switch?
Old Feb 10, 2012 | 12:38 PM
Slow91teg's Avatar
is it an automatic trans? if so it could be your gear shift not selecting the switch when it is in park.
Old Feb 10, 2012 | 12:45 PM
Barf Hat's Avatar
[QUOTE=Slow91teg;46839315]is it an automatic trans? if so it could be your gear shift not selecting the switch when it is in park.[/QUO
No its a manual
Heres anothere thing though. When I unistalled the bad ignition switch it had a wire running from the tumbuler system where the key goes in to the plug to the fire wall. When I looked at the factory manual it does not have this wire. the thing is its still the original car from 1995, so that is the switch it came with from the factory
Old Feb 10, 2012 | 12:58 PM
Hillsboro Locks's Avatar
First thing to know is, are you replacing the part that the key goes into (lock cylinder) or the switch on the back of the lock?
Honda/ Acura uses a longer X214 key used on 1996-2002 that replaced the shorter X195key used from 1993-1995. If the key is the shorter key it will go in and turn on but is too short to push in from postion 1 (accessory) to off/lock.
When removing the lock cylinder you have to turn key to accessory to push the retainer leaving the switch in accessory position. Sometimes people will turn the switch with a flat balde screw driver to turn back to off and that could cause a timing issue.
Old Feb 10, 2012 | 04:28 PM
92DAB16A's Avatar
Call the dealers my boys TL had a recall and the dealer installed a new one for a similar problem
Old Feb 10, 2012 | 04:40 PM
TheRealTegger's Avatar
How do you identify one type from the other?
And what about keys prior to '93?
Old Feb 10, 2012 | 04:42 PM
I think you replaced the lock cylinder, not the ignition switch. BIG difference!
Old Feb 11, 2012 | 07:18 AM
It would be really difficult for someone without alot of experience to notice the difference between the x214 and x195 key. I would advise you to have all keys made at a professional locksmith for all of your keys, especially car keys. With the cost of replacement parts for todays vehicles you can't afford to gamble with saving a few bucks.
Mid 80's thru 1990's keys are simple in design and easy to make.
Old Feb 12, 2012 | 06:56 AM
Barf Hat's Avatar
Um I think I know which part I replaced.
Old Oct 9, 2019 | 05:45 AM
BrandonNicole's Avatar
Can anyone here explain the ways to make a key without hiring any locksmith.
b00sted4dr
Jul 31, 2006 05:00 PM
bushrat
Jan 16, 2005 09:21 AM
EricUSC
Nov 1, 2003 09:38 PM
