B18c1 help
B18c1
So i got my 94 integra ls 4door with b18c1 engine
With p75 ecu
Been using it without vtec because solinoid ground and vtec pressure
Does'nt have pigtail wiring harness.
So i check all my wiring i found 1 pigtail harness that fits on the vtec pressure
Still no luck for d solinoid ground
I even had my p28 with chip connected .
Wat should i do next pls help?
With p75 ecu
what is with all these noobs not only not being able to read but also being unable to type a legible question in correct english?
anytime someone says "wat" you have to really wonder...
Sounds like he can't find the wiring for the VTEC solenoid. He's running a P75 since VTEC isn't wired. He found a plug in the bay that fits the solenoid, plugged it in, still no VTEC. Even after trying a chipped P28. That's my guess anyway.
Op you might have to run your own wires for the VTEC solenoid depending on what harness was used.
Maybe a mod can help him and move this to the integra forum?
Its cause you have a ls body harness. Theres no vtec wires in that half of the harness. So your engine harness with vtec wireing is plugged into a harness without.. So you would either have to get a vtec body harness from a 92-95 civic ex or a 94-95 integra gsr model. Or wire your own wires from the Ecu to the pigtail that plugs your engine harness to your body harness or all the way to the soliniod from the ecu.
Hope that helps. An yes next time post in the right section. Hopfully this can be moved without to much complaint from others in the type R section an you can get the help you need an maybe someone in the integra section will hook you up with a diagram or somthing.
B18c1
With p75 ecu
With p75 ecu
h kid
Jun 18, 2005 11:42 AM
AngelTeg
Aug 24, 2003 07:03 PM
