99 DX no start after removing dizzy. worked fine before.
99DX W/y7.
no codes fuel pump primes battery is good have tried starting it when jumped won't even crank. I'm thinking lose/bad ground ? starter doesn't click you can turn the key all you want....nothing. all I did was take the distributer off never touched the battery or anything else it worked fine before. Could use some input
Yes, I tried taking the cap off snapped one of the 3 bolts so it's stuck on there pretty good stopped after that.
starter has never acted up gave it a hit or two. the lights and all come on just nothing when I turn the key aside from the pump priming. it's not cranking/trying to turn over
yes but I've done this several times with my GS-R never hurt it will have a look at the fuses tomorrow never though of that may have shorted(blown fuse) something would seem odd but worth a check.
anyone know if the dx pump will work on it it's a 94 GSR
Hondacrf
Jun 16, 2017 04:13 AM
ohcrapgorillas
Jun 2, 2014 01:20 PM
junya16
Mar 1, 2003 07:30 PM
