Car Rolls when parked While in Gear
Old Oct 23, 2002 | 09:28 AM
paybac4223's Avatar
Default Car Rolls when parked While in Gear
I went to fire up my car this morning and let off of the ebrake while my car was parked in 1st gear and the car kinda stuttered then started to roll back...
the car was off... i cant ever remember this happening before and its not a steep incline...is my tranny going out on me? any suggestions? it did drive fine...
Old Oct 23, 2002 | 09:33 AM
ejprimo's Avatar
Default Re: Car Rolls when parked While in Gear (paybac4223)
maybe you were holding down the clutch and thats why it began to roll.
Old Oct 23, 2002 | 09:40 AM
paybac4223's Avatar
Default Re: Car Rolls when parked While in Gear (ejprimo)
wasnt holding the clutch...
Old Oct 23, 2002 | 09:58 AM
Project X's Avatar
It happened to me too, but my key was in the ACC/ON position. Take the key out and see if it does the same.
Old Oct 23, 2002 | 10:05 AM
sackdz's Avatar
Default Re: Car Rolls when parked While in Gear (Project X)
Mechanically, this cannot happen (assuming the car runs) unless:
a) there is no holding force left in the clutch
b) the gear wasn't fully engaged (halfway in)
c) you have no axles
d) you are missing teeth on a gear inside your transmission
e) you have stripped the splines on your mainshaft (like Sakai)
Did I miss any?
Old Oct 23, 2002 | 10:20 AM
kb58's Avatar
Banned
I've had that happen in various cars. All conditions being right, the wheels can backdrive the engine through the gears. I don't think it's *necessarily* a problem.
Old Oct 23, 2002 | 10:47 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: Car Rolls when parked While in Gear (PreloodDude)
umm.. if his clutch is fully engaged and its still slipping then he has a serious problem.. I don't think thats the prob..
Edit: I don't even think that is possible.. unless your flywheel fell out of your transmission or something.. LoL!
[Modified by Hatchy-Ownzjo0, 2:48 PM 10/23/2002]
Old Oct 23, 2002 | 11:39 AM
paybac4223's Avatar
my key was in the ignition...i'll try taking it out and try that...
Old Oct 28, 2002 | 10:00 AM
Project X's Avatar
Don't ask me why it did that, but it did. I would like to know why.
Old Oct 28, 2002 | 10:33 AM
sackdz's Avatar
Bullshit.
Old Oct 28, 2002 | 01:35 PM
robbin's Avatar
Are you sure you were in first gear? In higher gears its much easier for that to happen. If fifth for instance its quite easier to push a car slowly while its in gear.
Old Oct 28, 2002 | 02:11 PM
CXHatchback's Avatar
Default Re: Car Rolls when parked While in Gear (robbin)
How far did it roll back? Cause it'll roll back a little bit before it catches the engine.
Old Oct 28, 2002 | 03:01 PM
MaxED9's Avatar
Default Re: Car Rolls when parked While in Gear (CXHatchback)
its just like trying to turn the crank pulley... as soon as you get compression... no more movement... so:
A: you are really loosing compresion in your engine...
B: you were pressing the clutch and not realize it... ive done that before.hehe
if it just rolled a little bit it was your engine making a complete rotation... if it kept on rolling.... then i dunno wtf youve done to your car.
Bhoang
Honda Civic (2001 - 2005)
Mar 30, 2010 03:38 PM
mnskateboarder
Transmission & Drivetrain
11
Oct 25, 2009 08:01 PM
honda305
14
Oct 6, 2009 09:11 PM
Rocks.
Aug 22, 2005 03:12 PM
BlackOutIntegra
May 6, 2004 10:47 AM
