b20 block with gsr crank help?
Old Oct 24, 2002 | 07:29 PM
racecarpete's Avatar
Default b20 block with gsr crank help?
hi, i can get a nice deal on a b20 block with no crank and a gsr crank locally, I'm wondering if i can put this in and make it work I know people put gsr cranks in ls engines and the b20 is very similar to the ls but i just want to make sure. thanks
Old Oct 26, 2002 | 05:17 AM
JBONES's Avatar
Default Re: b20 block with gsr crank help? (SilverCivic2k)
if you put a gsr crank in a b20 it will destroke the motor....and what is the point of loseing all the torque of the b20....just find a gsr block to put it in.....my opiion sorry if its not what ya wanted to know
Old Oct 28, 2002 | 02:57 PM
blacksheep's Avatar
Default Re: b20 block with gsr crank help? (JBONES)
Not if the crank is a B17A crank from a 92-93 GS-R. If I'm not mistaken, the B17A crank has a longer stroke than any of the other B series engines.
Old Oct 28, 2002 | 03:10 PM
Kataku2K3's Avatar
Default Re: b20 block with gsr crank help? (blacksheep)
Nope, actually that is incorrect.... All B series except for the B20 have an 81mm bore. The difference is the stroke.. B17 has an 81.4mm stroke and the B18C has an 87.2mm stroke... that's where you get the extra displacement. About the girdle, you don't have to put it in but it does help... Just have the main caps milled.. Laterz
Old Oct 28, 2002 | 03:11 PM
Kataku2K3's Avatar
Default Re: b20 block with gsr crank help? (JDMspecEG6)
Also i forgot to add, if you drop a B17 crank in you'll be right back to 1.8L
AK94GSR
Sep 28, 2007 12:22 AM
hoskos
Jan 29, 2006 09:39 PM
hybridpatient95
20
Jan 4, 2005 05:07 PM
5w20
Dec 4, 2004 11:57 PM
lazy bum shaughn
Jun 14, 2004 01:55 AM
